• 1
    Step 1
    Create drilling templates for the front and base plates
    Figure out how many 3.3V, 5V, 12V, -5V, and -12V banana jacks you want to have in your front plate. I used two each for the high-current voltages (3.3V, 5V, and 12V) and one each for the low-current ones (-5V and -12V, prepared a hole for -3.3V just in case I need it later).
    The front plate will also hold a switch and two 3 mm LEDs (red for standby and green for power good). I also added holes for two cable glands.
    Mark the positions of each hole on a piece of paper (or print the whole thing, it doesn't matter).
    Do the same thing for mounting the front plate on the base plate. I used 4 M8 screws for that.
    Here's a picture of my front template:
    It's missing the marks for the switch and the LEDs, I added them later.
  • 2
    Step 2
    Drill front and base, mount front on base plate
    Straight forward: My banana jacks needed 8 mm holes, the cable glands needed 12 mm-ish (12.5? I'm not sure what I used), then there's 5 mm for the switch and 3.2 mm for the LEDs, and finally 8.5 mm for the mounting screws:
    I used additional spring washers for the M8 screws.
  • 3
    Step 3
