AutoCAD DXF - 125.08 kB - 05/22/2016 at 13:46 |
Adobe Portable Document Format - 440.17 kB - 05/20/2016 at 17:53 |
Adobe Portable Document Format - 1.32 MB - 05/12/2016 at 22:29 |
Adobe Portable Document Format - 2.67 MB - 05/12/2016 at 22:28 |
Adobe Portable Document Format - 4.37 MB - 05/12/2016 at 22:28 |
C:\Users\jeramy\Documents\BRLCAD 7.24.0\bin>dxf-g -dv "C:\\Users\\jeramy\\Documents\\BRL-CAD\\Grinder_Switch_Plate\\Grinder_Switch_Plate.dxf" "C:\\Users\\jeramy\\Documents\\BRL-CAD\\Grinder_Switch_Plate\\Grinder_Switch_Plate.g"
mged> units in
mged> draw sketch.1
mged> in arb1.s arb8 0 0 0 2.69 0 0 2.69 1.303 0 0 1.303 0 0 0 0.118 2.69 0 0.118 2.69 1.303 0.118 0 1.303 0.118
mged> in arb2.s arb8 0.9785 0.4030 0 1.7115 0.4030 0 1.7115 0.9 0 0.9785 0.9 0 0.9785 0.4030 0.118 1.7115 0.4030 0.118 1.7115 0.9 0.118 0.9785 0.9 0.118
mged> in rcc1.s rcc 0.18 0.6515 0 0 0 0.118 0.1050
mged> in rcc2.s rcc 2.51 0.6515 0 0 0 0.118 0.1050
mged> r grinder_switch_plate.r u arb1.s - arb2.s - rcc1.s - rcc2.s
mged> Z
mged> draw grinder_switch_plate.r
C:\Users\jeramy\Documents\BRLCAD 7.24.0\bin>g-stl -bi -o "C:\\Users\\jeramy\\Documents\\BRL-CAD\\Grinder_Switch_Plate\\Grinder_Switch_Plate(part).stl" "C:\\Users\\jeramy\\Documents\\BRL-CAD\\Grinder_Switch_Plate\\Grinder_Switch_Plate.g" grinder_switch_plate.r
{arb1.s} - {arb2.s}
{(arb1.s - arb2.s)} - {rcc1.s}
{((arb1.s - arb2.s) - rcc1.s)} - {rcc2.s}
168 triangles written
Load stl into Slic3r, and set scale to 2540% to convert in to mm.
Alternatively:
mged> units in
mged> in sketch.2 extrude 0 0 0 0 0 0.118 0.03937 0 0 0 0.03937 0 sketch.1
**Here the 0.03937 is the value 1/25.4, which is the factor for in/mm, and the value .118 is what I came up with for the height in in (which is 3mm). I came up with this because it is appropriate for the part, and I could easily check it when scaling the drawing in the slicer, because it is looking for the drawing to be in mm units, however I took all of my part measurements in standard units.
I don't understand why the A and B values have to be what they are, but it seems to be working.
(V: 0 0 0)
(H: 0 0 0.118)
(A: 0.03937 0 0)
(B: 0 0.03937 0)
(http://brlcad.org/wiki/Extrude)
C:\Users\jeramy\Documents\BRLCAD 7.24.0\bin>g-stl -bi -o "C:\\Users\\jeramy\\Documents\\BRL-CAD\\Grinder_Switch_Plate\\Grinder_Switch_Plate.stl" "C:\\Users\\jeramy\\Documents\\BRL-CAD\\Grinder_Switch_Plate\\Grinder_Switch_Plate.g" sketch.2
Comparison of the outputs:
C:\Users\jeramy\Documents\BRLCAD 7.24.0\bin>g-stl -bi -o "C:\\Users\\jeramy\\Documents\\BRL-CAD\\Grinder_Switch_Plate\\Grinder_Switch_Plate(extrude).stl" "C:\\Users\\jeramy\\Documents\\BRL-CAD\\Grinder_Switch_Plate\\Grinder_Switch_Plate.g"sketch.2
296 triangles written
{arb1.s} - {arb2.s}
Here you can see the difference in file sizes:
Scaled side by side comparison in slic3r:
Green is highlighted part.
I used printrun to make the part. https://github.com/kliment/Printrun
*** Don't create nonsensical regions, be mindful of the order that regions are created in, i.e.) don't union solids and then subtract holes. create appropriate combinations with holes subtracted, then create region of combinations, as necessary. Part will display correctly in mged, but will not properly create .stl.
https://sourceforge.net/p/brlcad/mailman/message/34711181/
TODO: Show examples.
Converting .dxf to .g
This file was saved in DraftSight as R2013 ASCII Drawing (*.dxf)
Output (what I was able to capture):
12600: ACDSRECORD
12601: 95
12602: 0
12603: 90
12604: 3
12605: 2
12606: AcDbDs::Legacy
12607: 280
12608: 1
12609: 291
12610: 1
12611: 101
12612: ACDSRECORD
12613: 1
12614: AcDbDs::ID
12615: 90
12616: 4
12617: 2
12618: AcDs:Indexable
12619: 280
12620: 1
12621: 291
12622: 1
12623: 101
12624: ACDSRECORD
12625: 1
12626: AcDbDs::ID
12627: 90
12628: 5
12629: 2
12630: AcDbDs::HandleAttribute
12631: 280
12632: 7
12633: 282
12634: 1
12635: 0
12636: ACDSSCHEMA
12637: 90
12638: 1
12639: 1
12640: AcDb3DSolid_ASM_Data
12641: 2
12642: AcDbDs::ID
12643: 280
12644: 10
12645: 91
12646: 8
12647: 2
12648: ASM_Data
12649: 280
12650: 15
12651: 91
12652: 0
12653: 101
12654: ACDSRECORD
12655: 95
12656: 1
12657: 90
12658: 2
12659: 2
12660: AcDbDs::TreatedAsObjectData
12661: 280
12662: 1
12663: 291
12664: 1
12665: 101
12666: ACDSRECORD
12667: 95
12668: 1
12669: 90
12670: 3
12671: 2
12672: AcDbDs::Legacy
12673: 280
12674: 1
12675: 291
12676: 1
12677: 101
12678: ACDSRECORD
12679: 1
12680: AcDbDs::ID
12681: 90
12682: 4
12683: 2
12684: AcDs:Indexable
12685: 280
12686: 1
12687: 291
12688: 1
12689: 101
12690: ACDSRECORD
12691: 1
12692: AcDbDs::ID
12693: 90
12694: 5
12695: 2
12696: AcDbDs::HandleAttribute
12697: 280
12698: 7
12699: 282
12700: 1
12701: 0
12702: ACDSSCHEMA
12703: 90
12704: 2
12705: 1
12706: AcDbDs::TreatedAsObjectDataSchema
12707: 2
12708: AcDbDs::TreatedAsObjectData
12709: 280
12710: 1
12711: 91
12712: 0
12713: 0
12714: ACDSSCHEMA
12715: 90
12716: 3
12717: 1
12718: AcDbDs::LegacySchema
12719: 2
12720: AcDbDs::Legacy
12721: 280
12722: 1
12723: 91
12724: 0
12725: 0
12726: ACDSSCHEMA
12727: 90
12728: 4
12729: 1
12730: AcDbDs::IndexedPropertySchema
12731: 2
12732: AcDs:Indexable
12733: 280
12734: 1
12735: 91
12736: 0
12737: 0
12738: ACDSSCHEMA
12739: 90
12740: 5
12741: 1
12742: AcDbDs::HandleAttributeSchema
12743: 2
12744: AcDbDs::HandleAttribute
12745: 280
12746: 7
12747: 91
12748: 1
12749: 284
12750: 1
12751: 0
12752: ACDSRECORD
12753: 90
12754: 0
12755: 2
12756: AcDbDs::ID
12757: 280
12758: 10
12759: 320
12760: 22
12761: 2
12762: Thumbnail_Data
12763: 280
12764: 15
12765: 94
12766: 1287
12767: 310
12768: 89504E470D0A1A0A0000000D49484452000001000000008808030000003F38C55500000
00504C544595989D000000FFFFFF000000000000000000000000000000000000000000000000000
330000660000990000CC0000FF0033000033330033660033990033CC0033FF00660000663300666
0066990066CC0066FF0099
12769: 310
12770: 000099330099660099990099CC0099FF00CC0000CC3300CC6600CC9900CCCC00CCFF00F
0000FF3300FF6600FF9900FFCC00FFFF3300003300333300663300993300CC3300FF33330033333
3333663333993333CC3333FF3366003366333366663366993366CC3366FF3399003399333399663
99993399CC3399FF33CC00
12771: 310
12772: 33CC3333CC6633CC9933CCCC33CCFF33FF0033FF3333FF6633FF9933FFCC33FFFF66000
6600336600666600996600CC6600FF6633006633336633666633996633CC6633FF6666006666336
66666666996666CC6666FF6699006699336699666699996699CC6699FF66CC0066CC3366CC6666C
9966CCCC66CCFF66FF0066
12773: 310
12774: FF3366FF6666FF9966FFCC66FFFF9900009900339900669900999900CC9900FF9933009
33339933669933999933CC9933FF9966009966339966669966999966CC9966FF999900999933999
669999999999CC9999FF99CC0099CC3399CC6699CC9999CCCC99CCFF99FF0099FF3399FF6699FF9
99FFCC99FFFFCC0000CC00
12775: 310
12776: 33CC0066CC0099CC00CCCC00FFCC3300CC3333CC3366CC3399CC33CCCC33FFCC6600CC6
33CC6666CC6699CC66CCCC66FFCC9900CC9933CC9966CC9999CC99CCCC99FFCCCC00CCCC33CCCC6
CCCC99CCCCCCCCCCFFCCFF00CCFF33CCFF66CCFF99CCFFCCCCFFFFFF0000FF0033FF0066FF0099F
00CCFF00FFFF3300FF3333
12777: 310
12778: FF3366FF3399FF33CCFF33FFFF6600FF6633FF6666FF6699FF66CCFF66FFFF9900FF993
FF9966FF9999FF99CCFF99FFFFCC00FFCC33FFCC66FFCC99FFCCCCFFCCFFFFFF00FFFF33FFFF66F
FF99FFFFCCFFFFFF0000000D0D0D1A1A1A2828283535354343435050505D5D5D6B6B6B787878868
86939393A1A1A1AEAEAEBB
12779: 310
12780: BBBBC9C9C9D6D6D6E4E4E4F1F1F1FFFFFF0000000000000000000000000000000000000
0000000000000000000000533D0435000000097048597300000EC400000EC401952B0E1B000001A...
1) Import this image into gimp
2) create new image, same size, with black background
3) copy paste skull onto black background, anchor layer
4) set image mode to indexed, black and white
5) export as .data file (Standard (R, G, B); B, G, R, X (BMP style))
(save exported file in the same folder as the working .g database)
6) mged> in ebm1.s ebm had_logo.data 870 794 5
7) mged> l ebm1.s
Output:
ebm1.s: extruded bitmap (EBM)
file="had_logo.data" w=870 n=794 depth=5
mat=1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1
Ummmm..... There was no point in creating multipane drawings if you are going to show the same view in all of them. (TODO: FIX THESE VIEWS)
tor
eto
part
nmg (nmg editing link)
come back to this one ...
pipe
ars
metaball
nurb (?)
This is listed in the primitives section, but there is no command for it.
spline (?)
vol
bot
poly
depreciated, use bot instead
Command:
in ell3.s ell 0 0 0 0 -1 0 1 0 0 0 0 1
Primitive: ell
Command:
* when you type " l sph1.s"An output similar to the following is generated. The geometry is listed as an ellipsoid because a sphere is a special form of ellipsoid.
sph1.s: ellipsoid (ELL)
V (132.304, -34.6358, -292.896)
A (565.678, 0, 0) mag=565.678
B (0, 565.678, 0) mag=565.678
C (0, 0, 565.678) mag=565.678
A direction cosines=(0, 90, 90)
A rotation angle=0, fallback angle=0
B direction cosines=(90, 0, 90)
B rotation angle=90, fallback angle=0
C direction cosines=(90, 90, 0)
C rotation angle=0, fallback angle=90
Command:
Command:
Command:Command:
arb arb1.s 0 0
in arb8.s arb8 (this command will prompt you to enter the {X, Y, Z} for the 8 points)
in arb9.s arb8 0 0 0 20 0 0 20 20 0 0 20 0 0 0 2 20 0 2 20 20 2 0 20 2
*this is the same as if the following was entered on the previous command
Enter X, Y, Z for point 1: 0 0 0
Enter X, Y, Z for point 2: 20 0 0
Enter X, Y, Z for point 3: 20 20 0
Enter X, Y, Z for point 4: 0 20 0
Enter X, Y, Z for point 5: 0 0 2
Enter X, Y, Z for point 6: 20 0 2
Enter X, Y, Z for point 7: 20 20 2
Enter X, Y, Z for point 8: 0 20 2
Command:
Command:
Command:
Command:
Command:
TODO: write python program with qt interface to ease geometry conversion process.
I've got that in the works, just added feature to enable slicing a model to individual STL files:
https://github.com/nmz787/python-brlcad-tcl
next in the works is using BRL-CAD's NIRT tool to interrogate the internal representation at any needed resolution and generate a raster (and then g-code or other raster outputs for various CAM tools).
I have been playing with this https://github.com/kanzure/python-brlcad, but it was a pain to get it built, on windows at least. Since building it, if I needed it on another computer, I just copied the compiled brl-cad folder.
I have come across your project in the past as well, and run some of the examples, I will go back and take another look. You have made some up dates since the last time I saw the github page.
I know that project and the developer, basically generating the wrappers was too much manual work and wasn't easily automated. I also wasn't able to get far with his method, so went ahead and just started to 'abuse' the TCL interface. So far I am pretty happy :)
I just added raster generation for slices of a model and some other light re-factoring.
Please report requests or issues to the github repo! I hope you find it useful!!
