Robot hand with Opposable Thumb
Robot hand with opposable thumb - one piece 3D printed with Flexible PLA
I set myself a task to create a single 3D printed hand with an "Opposable" thumb.
The design I present here comes from some of my previous designs.
The Basic hand has a backplane , the flexible_ish part.
The cable ductings are built into the base and carry the Fishing Gut from wrist to finger tips/opposable thumb and knuckles.
Finished print took circa 2 hours and lifted off the heat bed like a non-stick frying pan. To help with the springback of the fingers after activation I coated on the back thin tracks of elastic silicon sealant,this worked wonders and gave a good realistic action.
Now I am awaiting some metal gear servos to finish it off...
Video of construction :-
Video of Operation the thing is alive :-
Video of dexterity and speed :-
  • 1 × Flexible PLA
  • 1 × Fishing gut
  • 1 × Silicon elastic sealant
  • MyRobotLab (aka MRL)
    chiprobot05/25/2014 at 09:12 0 comments
    There was only one place to go next ......... to pick up the latest version of MRL
    As luck would have it Galiant GroG was live in his shoutbox, so I was quickly diverted to lots of goodies and solutions.
    .... and a short time later MRL was controlling my hand now dubbed by GroG as "The Gauntlet"
  • Servo Stack (aka Wrist)
    chiprobot05/25/2014 at 09:10 0 comments
    The 3D printed Servo Stack has now be designed.
    Designed to print no support material (using Blenders Mesh Anaysis command to check for overhangs,distortions,thickness)
    ....Below awaiting the HeatPlate to cool down.
    Here I have attached the Flexible hand to the Servo stack.
View all 2 project logs
Jasmine Brackett wrote 06/23/2014 at 23:18 point
Hello Chiprobot, would love to see a little video of the hand moving.
I noticed you tagged this project with 'thehackadayprize', but have not officially submitted it.
We updated the submission process a little while ago, so you need to login and use the 'submit to' under your project images on the left hand side.
We've started community voting, so if you want a chance of winning one of the phases you should officially submit asap.
Good luck!
chiprobot wrote 03/07/2016 at 20:25 point
Better late than never..... tag removed and Videos added :-)
