Wiring unit
A project log for Air Pressure Quadcopter
Intake duct, Control Module, Fan 1, Forward/Backward Left/Right servo motion design, Fan 2, Battery, Recycle Duct, 8 tubes, All inside one u
future1xtechFuture1xtech 04/16/2018 at 17:140 Comments
started wiring unit from bottom up.
Connected battery wires
Set rechargeable plug on outside
Connected motor wires
Ran both wires up the unit and taped all wires out of fans way.
Connected top motor wires and connected top motor duct to top of unit.
TEST MODE.... connected battery to both motors and fans spin as designed.
(This unit must be sealed tight)
Far from done still work progress to be made.
Thank you for viewing.
