Glucose test strip connectors
A project log for Open source Arduino blood glucose meter shield
Open hardware and software blood glucose meter using electrochemical test strips
m-bindhammerM. Bindhammer 05/24/2016 at 17:546 Comments
The most critical part of the PCB will be the glucose test strip connector to my surprise. Only a few companies like Ample Technologies will provide those test strip connectors. I learned that these test strip connectors are protected by patents and IPs. You need to answer a lot of questions if it is for personal hobby or education use or for prototyping phase which eventually goes into mass production.
I am in contact with Ample Technologies now. Let's see, if they will provide some samples of connectors, suitable for the ONE TOUCH ULTRA test strips...
In the mean time I found a Taiwanese company called Switchtech which has a connector suitable for the ONE TOUCH ULTRA test strips. They will provide 50 samples FOC, I only need to pay for the shipment. I attached the datasheet under FILES.
Samples received:
Pin diagram of the ONE TOUCH ULTRA test strip connector:
The two strip detect pins are connected if the test strip is correctly inserted.
Chayma wrote 01/30/2017 at 09:58 point
Hi,
I need this glucose meter connector for my project graduation. Can you help and send me how can I get this connector because i don't get a response from switchtec. Thanks.
M. Bindhammer wrote 09/20/2016 at 14:07 point
I think they only want to do business with a company. I ordered the samples through my company.
Vishnu Pradeep wrote 10/01/2016 at 06:18 point
Thanks. Switchtech has responded. Ample Tech is actually official distributor of switchtech components. Through Ample tech I could get in touch with SwitchTech now. They told me they'll send the samples soon.
Vishnu Pradeep wrote 09/03/2016 at 12:06 point
Hi,
Can you specify the model number of the connector you bought?
Thanks,
Vishnu
Vishnu Pradeep wrote 09/20/2016 at 12:58 point
Thanks a lot. I've designed board with this connector. enquired the availability of the same connector with Ample technologies. How did you received the sample from Switchtech. They are not even responding to any of my emails.
