*HELLO* !
A project log for Modular Unmanned Vehicle Controller
(former YAUVeC - Yet Another Unmanned Vehicle Controller)
e-n-heringE. N. Hering 01/19/2017 at 03:272 Comments
Hi!
Today the RN131G WiFi module had its firmware successfully upgraded to version 4.41 and I could connect to it via Telnet.
This module is already mounted in his horseshoe PCB breakout and connected to the communications MCU module via the backbone PCB.
This means that now I can connect to the MCU module via WiFi!
My next step is to start to assemble the sensor submodule. Soon I'll publish the sensor readings via WiFi here.
Thank you for your support!
E. N. Hering wrote 01/19/2017 at 19:57 point
Hi loldavid6! Thanks for your message!
Regarding your question, I'm using SPI to communicate between boards. I defined a very simple protocol that is currently working well. The COM module sends questions to other modules as integers, and they answer with data types, sizes and information. I do not know about UAVCAN, but will google it.
SPI was selected as the backbone protocol because atmega328p is very cheap, well supported and has two SPIs when not running arduino code. I dedicated one of the SPIs to the bus and the other one to talk to the submodule. To use CAN instead of SPI I would have to change the micro controller.  As everything is modular, it can be done without problems, but will require us to design a new MCU module with a MCU that supports CAN and may require a change in the backbone connections. If you wish to help, it would be a very nice upgrade to the system. I can help you with that if necessary.
I can send you a kit of PCBs if you wish. You just pay for the cost of the boards and for the shipment. I can even send you the components too, but I'll have to calculate their cost.
Thanks again for your message.
loldavid6 wrote 01/19/2017 at 15:24 point
Hey, it been a while since I contacted you last, life caught up on me.  I love how your project has been progressing!
Does you board use use UAVCAN?  If not would you at any point consider implementing it into your design?
Also, I would be interested in purchasing a panel.
Keep up the good work!
