Arduino based Build Indicator
Strobe light wired to an Arduino with a transistor switch that activates when our continuous build fails.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I found a red strobe light in the bargain bin at a local electronics store and immediately knew what to do with it – create a build failed light. There is a long history of dev shops creating build indicator lights using lava lamps, stop lights and computer monitors mounted on the wall and I’ve always wanted to build one.
