Otto Wiring update
A project log for Otto DIY
build your own robot in less than one hour!
camilo-parra-palacioCamilo Parra Palacio 08/09/2016 at 05:416 Comments
asy to read ;) you can also check the 123D circuit diagram or produce a custom PCB using the Gerber files.
https://circuits.io/circuits/1749080-otto-circuit
Camilo Parra Palacio wrote 08/22/2016 at 07:30 point
got it! thanks for sharing Radomir
deʃhipu wrote 08/10/2016 at 07:36 point
By the way, you might want to add some kind of additional marks on the cables signifying their colors, like some kind of a pattern on them -- I've seen people stumbling with color-coded diagrams like this when the lightning is not perfect or a mild case of color blindness is involved.
Camilo Parra Palacio wrote 08/22/2016 at 02:57 point
Thanks Radomir like dash lines?, also for ultrasound our colors do not match the ones that comes in the kit so would like to see an example of how to solve this.
deʃhipu wrote 08/22/2016 at 07:22 point
It doesn't need to be dash lines, for instance, look at this:
Anything that is easy to distinguish while printed in grayscale would be sufficient.
Camilo Parra Palacio wrote 08/10/2016 at 01:09 point
Radomir you are right, updated thanks :)
deʃhipu wrote 08/09/2016 at 15:06 point
Aren't the Echo and Vcc pins swapped?
