Shared Silicon
Silicon proven way to reduce the cost of integrated circuit manufacturing by collaboration
Public Chat
I had one semi-successful tapeout in 2015 (it was not 100% success because chip was slow). I have a library of CMOS 0.5um components that was designed by me in Magic and I want to share it with others (and I use extreme form of open source here - namely "public domain") with hope that others will share silicon with me on my next tapeouts to reduce price for each of us. I offer manufacturing of 40 silicon dies packaged in DIP40 ceramic package and each die could be divided up to 4 parts and each part could be occupied by separate project with separate power (to prevent short-circuit in one part to kill whole chip). Dies could be packaged differently, but for now assumption is everything must be DIP40 and each participant will get proportional amount of chips (if you occupy 25% of the die then you get only 10 chips). Because all participants will see all designs everything must be open source - no proprietary or patented parts are allowed! For business entities only!!!
Results of my 1st tapeout received on October 20th, 2015:
Initially it was 8 packaged and 32 unpackaged chips:
Later I packaged all unpackaged dies and got 3 different packages for the same die - DIP40, DIP28 and SOIC16:
Chip itself is 3 separate test projects on one silicon die:
Each test project is a collection of CMOS circuits to test basic building blocks for binary, ternary and quaternary logic. Work was done in conjunction with a stealth hardware start-up that will reveal more details soon...
Magic VLSI layout open source tool: http://opencircuitdesign.com/magic/
Technology files for Magic: http://opencircuitdesign.com/magic/tech.html
We use SCN3M.35 technology (0.5um lambda=0.35).
To run Magic with this technology files:
magic -T SCN3M.35
Below you can see very helpful Magic tutorial from Youtube user CellRider:
nedocon-cmoslib.zip
Alpha-version of open source CMOS library of IC building blocks with models for LTSpice and layouts for Magic (kind of silicon proven for 0.5um)
Zip Archive - 676.95 kB - 10/03/2016 at 03:52
Download
  • Received my chips from efabless
    SHAOS07/27/2023 at 07:22 0 comments
    Received 2 packages from efabless - both my designs were manufactured:
    Each package has USB-cable, 2 motherboards, 10 daugher-boards with chips and 100+ chips packahed in QFN64.
    Process of testing of those chips is described in different Hackaday-project:
    https://hackaday.io/project/192099-lab-computer-marina
    And another way - TinyTapeout - is not yet ready....
  • Trying other ways to make chips
    SHAOS12/05/2022 at 03:27 8 comments
    Currently I'm trying to jump to the last car of efabless train :)
    - made a few test designs for TinyTapout that goes with efabless 130nm process as part of TT02;
    - and also submitted 2 open source test designs to efabless 1st 180nm process that should go through GlobalFoundries
    Nothing fancy, because everything is done through Verilog - you can actually draw your schematics in Wokwi but it's eventually converted to Verilog as well. Good thing is that self-made latches are translated to low level almost as is:
    This is a Muller gate (or C-gate) and if it will work as intended on actual chip then it means async designs are very possible with this Yosys driven process :)
  • Estimation of area for ternary selector
    SHAOS12/17/2017 at 03:05 0 comments
    In order to calculate how heavy TRIASIC could be with current limitations let's estimate how compact a ternary selector could be using our library of gates. If you paid attention to this project then you probably remember that ternary selector (multiplexer/demultiplexer) on 1st chip was implemented from binary gates manifesting analog behavior as showed below:
    This is how it looked in "spread" form (large squares are "filler cells" that do nothing):
    So one ternary selector has:
    3-input NAND gates: 2
    3-input NOR gates: 2
    2-input NOR gates: 1
    NOT gates: 6
    Transmission gates: 3
    TG and NOT gates are "low-profile" gates that could be only 53 units high and 3-input gates have 64-unit height. We can arrange elements in 2 rows - NOT and TG in one row and NAND/NOR in another row.
    Width of elements:
    3-input NAND gate - 38 units
    3-input NOR gate - 38 units
    2-input NOR gate - 30 units
    NOT gate - 22 units
    Transmission gate - 29 units
    1st row (NOT and TG): 6*22+3*29=219 units wide and 53 units high
    2nd row (NAND and NOR): 4*38+30=182 units wide and 64 units high
    Between rows we will have 7+7+3=18 units for 2 metal interconnects, so total height will be 53+64+18=135 units (47um) and total width 219 units (77um) - this is 20 modules from side to side horizontally and vertically we can put 25 rows of such modules (if we allocate space between them for 5 metal lines of interconnects) or totally 20*25=500 ternary selectors.
    And at the end one more picture from that 1st chip ;)
  • NAND ASIC
    SHAOS12/10/2017 at 08:27 0 comments
    I have an idea of  "NAND ASIC" in 2x2 mm when on chip itself we only have 2-input NAND gates and metal layers do interconnects between those NAND gates to implement something as NEDONAND in silicon :)
    Let's count how many gates we may have - 1 gate occupies 30x57 units (lambdas) that is 10.5x20 um:
    We have 2000x2000 um area where we will put pads and power rings so available area will be about 1550x1550 um. NAND gates may be arranged in the rows one after another like this:
    So in 1 row we may put 147 2-input NAND gates. Then we may have a number of horizontal lines in metal layer 1 or 2 after each row for interconnect - every line will take 3 lambdas for spacing and 4 lambdas for metal itself, so it's 7 lambdas per line plus additional 3 lambdas per spacing between next row of NAND gates. Let's calculates how many gates we may put on single chip if we will have N metal lines between rows of NAND gates:
    N=3 : interconnect will take 3*7+3=24 lambdas or 8.4um so height of every row will be 28.4um and on the chip we may have 1550/28.4=54 rows or 147*54=7938 NAND gates
    N=5: 5*7+3=38 lamdas or 13.3 um so 33.3 um for row, 1550/33.3=46 rows or 147*46=6762 NAND gates
    N=7: 7*7+3=52 lamdas or 18.2 um, 38.2 um for row, 40 rows or 147*40=5880 NAND gates
    N=9: 9*7+3=66 or 23.1 um, 43.1 um for row, 36 rows or 5292 NAND gates
    I'm still not sure how many interconnection lines will be good enough for most designs - probably I need to "synthesize" something 1st to see how it will go...
    P.S. Next step - to design compact layout for ternary multiplexer/demultiplexer ( see https://hackaday.io/project/11779/log/47306-useful-outcome ) to make ternary ASIC prototype as well (half of the chip might be binary NAND-ASIC prototype with for example NEDONAND implemented and another half - ternary TRI-ASIC prototype with for example parts of TRIADOR implemented ; )
  • Planning next "tapeout"
    SHAOS12/02/2017 at 04:03 10 comments
    According to this page:
    https://www.mosis.com/db/pubf/fsched?ORG=ON-SEMI
    in 2018 MOSIS will collect C5F/C5N 0.5um designs on these dates:
    • April 2nd
    • August 6th
    • December 3rd
    So we can choose April 2nd, 2018 as possible next "tapeout" date for our 2nd chip - anybody interested? ;)
    Maximal possible size of the die for minimal cost is 4 mm^2 now (it could be square 2x2 mm or 2000x2000 um) and we will order minimal possible quantity - 40. Planned packaging was DIP40, so die may have 40 pads on it (10 pads on each side of the die). Our old pad generator will not work, because last time die had slightly bigger size - 2.2x2.2mm (to meet 5mm^2 limit at that time).
    Technically possible to put more pads - if we will keep the same sizes and spacing as last time (100x100um pads with 50um between each other and 25um from pads to border - actually it was recommended size by MOSIS) then we can put N*150 on each side and for 2000um it will be N=13, so it's 13+13+11+11=48 max and now, surprise-surprise, DIP48 is also available as an option for packaging (even though slightly more expensive)!
    Now I plan to have everything OPEN SOURCE and fully available on every stage of the work under PUBLIC DOMAIN :)
  • Useful outcome
    SHAOS10/09/2016 at 15:49 0 comments
    As I said before my 1st chip is a collection of test circuits for binary, ternary and quaternary building blocks. One of that building blocks could be used directly even right now - it is ternary selector (that could connect 1 pin to any other 3 using 1-wire ternary control). SOIC16 package has only this building block wired to pins with this pinouts:
    Pin 1 - Vss (negative voltage)
    Pin 2 - MUST BE GROUNDED (Vss)
    Pin 3 - S (analog input "select")
    Pin 4 - N (analog input/output "negative")
    Pin 5 - O (analog input/output "neutral")
    Pin 6 - P (analog input/output "positive")
    Pin 7 - C (analog output/input "common")
    Pin 8 - Vdd (positive voltage)
    Pin 9 - MUST BE GROUNDED (Vss)
    Pin 10 - NOT CONNECTED
    Pin 11 - NOT CONNECTED
    Pin 12 - NOT CONNECTED
    Pin 13 - NOT CONNECTED
    Pin 14 - NOT CONNECTED
    Pin 15 - NOT CONNECTED
    Pin 16 - Vss (negative voltage)
    I designed a break-out board to convert SOIC to SIP (breadboard friendly):
    It's working pretty well (except the fact that switching frequency is limited to 20 kHz):
    Oscillograms if selector connected as ternary buffer (N = -5V, O = 0V, P = +5V):
    Oscillograms if selector connected as ternary inverter (N = +5V, O = 0V, P = -5V):
    And below you can see respective SPICE simulations generated by ngspce on model extracted from final chip layout (with models of PMOS and NMOS transistors for chosen CMOS technology found on Internet):
    Schematics of this selector:
    Above ternary circuit is based on regular binary blocks described before - NOT, NAND, NOR and TG. Here I use effect of shifting of threshold of NAND and NOR binary gates if all or some inputs connected together (LTspiceIV simulation):
    As you can see there are gaps between active zones (kind of "break-before-make" non-shorting transition) to prevent switches (X12,X13,X14) to be ON simultaneously while moving between zones (and it may cause short circuits between power lines because any of pins N,O,P could be connected to most positive or most negative voltage to implement some ternary functions using this universal ternary selector).
  • Filling cell
    SHAOS10/07/2016 at 04:00 0 comments
    Manufacturing required to fill all empty spaces by some filling cells that have metal layers and poly to meet density rule - this should support all neighboring designs. I created this cell 10x10um with 3 metal layers and poly layer connected to each other:
    This is how CIF-viewer showed this (and how it looks on actual silicon - with "fingers"):
    Problem is (and I think it's main reason of chips slowness) there is no connection to the ground (P-substrate here)! So chip is having a lot of floating capacitors between signals and ground that eat all dynamic - it has to be fixed before 2nd tapeout...
  • Pads generator
    SHAOS10/04/2016 at 19:49 10 comments
    This simple straightforward script generates 40 pads (each 100x100um) and power rings (VDD & VSS) for 2.2x2.2mm CMOS 0.5um design (silicon proven in 2015):
    # Generating DIP40 pads and VDD/VSS rings for SCN3M 0.5um process
    # This script is PUBLIC DOMAIN - use it on your own risk!
    rm -f pad.* pads.*
    magic  -T SCN3M.35 -dnull -noconsole << EOF
    drc off
    box position 0 0
    box size 100um 100um
    paint pad
    label IO
    save pad
    cif
    erase
    cellname rename pad pads
    # Pads
    box position 2085um  980um
    getcell pad
    box position 2085um 1130um
    getcell pad
    box position 2085um 1280um
    getcell pad
    box position 2085um 1430um
    getcell pad
    box position 2085um 1580um
    getcell pad
    box position 2085um 1730um
    getcell pad
    box position 1730um 2085um
    getcell pad
    box position 1580um 2085um
    getcell pad
    box position 1430um 2085um
    getcell pad
    box position 1280um 2085um
    getcell pad
    box position 1130um 2085um
    getcell pad
    box position  980um 2085um
    getcell pad
    box position  830um 2085um
    getcell pad
    box position  680um 2085um
    getcell pad
    box position  530um 2085um
    getcell pad
    box position  380um 2085um
    getcell pad
    box position   25um 1730um
    getcell pad
    box position   25um 1580um
    getcell pad
    box position   25um 1430um
    getcell pad
    box position   25um 1280um
    getcell pad
    box position   25um 1130um
    getcell pad
    box position   25um  980um
    getcell pad
    box position   25um  830um
    getcell pad
    box position   25um  680um
    getcell pad
    box position   25um  530um
    getcell pad
    box position   25um  380um
    getcell pad
    box position  380um   25um
    getcell pad
    box position  530um   25um
    getcell pad
    box position  680um   25um
    getcell pad
    box position  830um   25um
    getcell pad
    box position  980um   25um
    getcell pad
    box position 1130um   25um
    getcell pad
    box position 1280um   25um
    getcell pad
    box position 1430um   25um
    getcell pad
    box position 1580um   25um
    getcell pad
    box position 1730um   25um
    getcell pad
    box position 2085um  380um
    getcell pad
    box position 2085um  530um
    getcell pad
    box position 2085um  680um
    getcell pad
    box position 2085um  830um
    getcell pad
    # Corner markers
    box size 50um 50um
    box position 0 0
    paint psc
    box position 2160um 0
    paint psc
    box position 2160um 2160um
    paint psc
    box position 0 2160um
    paint psc
    # Ground ring
    box position 175um 175um
    box size 1860um 1860um
    paint m1
    box position 180um 180um
    box size 1850um 1850um
    paint psc
    box position 195um 195um
    box size 1820um 1820um
    erase
    paint m1
    box position 178um 178um
    box size 20um 20um
    erase
    paint m1
    box size 15um 15um
    paint psc
    box position 2012um 2012um
    box size 20um 20um
    erase
    paint m1
    box position 2015um 2015um
    box size 15um 15um
    paint psc
    paint m1
    box position 178um 2012um
    box size 20um 20um
    erase
    paint m1
    box position 180um 2015um
    box size 15um 15um
    paint psc
    paint m1
    box position 2012um 178um
    box size 20um 20um
    erase
    paint m1
    box position 2015um 180um
    box size 15um 15um
    paint psc
    box position 200um 200um
    box size 1810um 1810um
    erase
    # Power ring
    box position 210um 210um
    box size 1790um 1790um
    paint nw
    paint m1
    box position 215um 215um
    box size 1780um 1780um
    paint nsc
    box position 225um 225um
    box size 1760um 1760um
    erase
    paint nw
    paint m1
    box position 213um 213um
    box size 15um 15um
    erase
    paint nw
    paint m1
    box size 10um 10um
    paint nsc
    box position 1982um 1982um
    box size 15um 15um
    erase
    paint nw
    paint m1
    box position 1985um 1985um
    box size 10um 10um
    paint nsc
    box position 213um 1982um
    box size 15um 15um
    erase
    paint nw
    paint m1
    box position 215um 1985um
    box size 10um 10um
    paint nsc
    box position 1982um 213um
    box size 15um 15um
    erase
    paint nw
    paint m1
    box position 1985um 215um
    box size 10um 10um
    paint nsc
    box position 230um 230um
    box size 1750um 1750um
    erase
    save pads
    cif
    quit -noprompt
    EOF
    Result is pads.mag file (and pads.cif just in case) that looks like this:
  • CMOS transmission gate
    SHAOS10/03/2016 at 04:20 0 comments
    LTSpiceIV model:
    Test circuit for LTSPiceIV:
    Magic layout:
  • CMOS NOR gate
    SHAOS10/03/2016 at 04:15 0 comments
    LTSpiceIV model:
    Voltage transfer curve:
    When both inputs change state together threshold shifts left (blue line).
    Magic layout:
    3-input version:
    LTSpiceIV for it:
View all 12 project logs
Yann Guidon / YGDES wrote 03/05/2023 at 19:25 point
https://hackaday.com/2023/03/05/tiny-tapeout-3-get-your-own-chip-deign-to-a-fab/
SHAOS wrote 03/16/2023 at 10:05 point
TT03 is here :)
Yann Guidon / YGDES wrote 12/30/2019 at 17:19 point
XOR gates are indispensable...
Here are various implementation choices :
https://hackaday.io/project/8449-hackaday-ttlers/log/150147-bipolar-xor-gate-with-only-2-transistors/
Will you add a XOR2 gate to your lib ?
SHAOS wrote 12/31/2019 at 01:05 point
Actually I have one (classic CMOS version), but I didn't make it public yet ;)
Yann Guidon / YGDES wrote 03/07/2020 at 14:41 point
Would you release it some day ?
SHAOS wrote 03/15/2020 at 02:34 point
Definitely
Yann Guidon / YGDES wrote 09/09/2019 at 10:44 point
I'm looking for ways to combine "decap cells" and "well tap cells"... any idea ? :-)
no idea :)
Yann Guidon / YGDES wrote 09/04/2019 at 03:41 point
I'm looking at advanced techniques and discover more and more... did you know about this one ? https://youtu.be/7NctVo0BL3s?t=258 "decap cells"...
Well Tap Cells are interesting too.
I'm sure the slowness of your first run can be explained by several "details" such as these.
SHAOS wrote 09/08/2019 at 04:34 point
Thanks, I never heard about that (at least it was not in CMOS books that I read)
Yann Guidon / YGDES wrote 09/08/2019 at 14:06 point
You're welcome :-) I'm slowly trying to catch up with the advances of the latest 30 years ;-) I'm familiar with the methods of the 70s and 80s but some serious development happened in the 90s that changed many rules established by Mead & Conway... https://en.wikipedia.org/wiki/Mead_%26_Conway_revolution
I notice that your gates library has only one output strength "option" whereas libraries often have 2 or 3. Look at https://hackaday.io/project/162594/log/168297-a-taste-of-a-real-design :-D
SHAOS wrote 09/15/2019 at 03:15 point
I have "stronger" inverter to put 2 of them after some gates where needed ;)
ChenKenLuPi wrote 11/02/2018 at 01:28 point
You're clearly out and away ahead of me,
but this is the way to go.
Let me know if you need hands on deck.
Yann Guidon / YGDES wrote 08/18/2018 at 23:31 point
How do you deal with bias ?
This log has many interesting thoughts about this issue :
http://www.righto.com/2018/08/inside-die-of-intels-8087-coprocessor.html
Curiously, it's not something I've ever seen covered anywhere so far, yet there is an IEEE standard ?
SHAOS wrote 08/18/2018 at 23:50 point
I thought CMOS doesn't require one - ok, I'll check this out...
SHAOS wrote 04/25/2018 at 08:18 point
I know, I know...
Yann Guidon / YGDES wrote 10/22/2016 at 20:59 point
I still can't join this project :-(
SHAOS wrote 10/22/2016 at 23:53 point
You're still invisible :(
David Anders wrote 10/09/2016 at 03:26 point
this is great! i was already looking at some broker houses for fab shops! the idea of using a die with Chip-On-Board(CoB) sounds perfect for this!
SHAOS wrote 10/10/2016 at 02:43 point
For CoB I need to buy a bonding machine (and it is not so easy)
Yann Guidon / YGDES wrote 10/10/2016 at 13:08 point
but that's the way to go ! :-D
SHAOS wrote 10/10/2016 at 13:47 point
Eventually - yes
Yann Guidon / YGDES wrote 10/05/2016 at 01:31 point
You also need to design distributed on-die capacitors for better power supply decoupling... This could also help a little with your speed issues. All that unused space could have been turned into an energy storage...
SHAOS wrote 10/05/2016 at 01:40 point
Capacitors (and resistors) on silicon are also gonna be huge and take space...
Yann Guidon / YGDES wrote 10/05/2016 at 08:11 point
But you have left a lot of space unused.
SHAOS wrote 10/05/2016 at 12:11 point
My next tape-out will be fully occupied ;)
Yann Guidon / YGDES wrote 10/06/2016 at 06:59 point
Did you just start the "Occupy Silicon" movement ? :-P
SHAOS wrote 10/06/2016 at 11:59 point
Yeah :)
Yann Guidon / YGDES wrote 10/04/2016 at 00:38 point
One obvious and direct application will be to redesign the #Yet Another (Discrete) Clock in this CMOS technology. I'm already imagining how it would be possible to translate the 10TFF :-D
SHAOS wrote 10/05/2016 at 01:41 point
I think a lot of projects here on Hackaday may be easily translated into this :)
Yann Guidon / YGDES wrote 10/03/2016 at 23:38 point
Pro-tip : Concerning your gates library, think about creating mirrored and rotated versions in every possible combination, to reduce wire length and ease routing ;-)
SHAOS wrote 10/03/2016 at 23:45 point
I read somewhere that all transistors in CMOS must be oriented exactly the same way because of some feature of silicon, so idea is all blocks are having the same height and could be arranged in the row where top is positive power and bottom is negative power (ground). Between rows I have channels for 5 horizontal metal lines for forward and backwards connections. Vertical connections could be done in 3rd metal layer that can go over transistors with no problems.
Yann Guidon / YGDES wrote 10/03/2016 at 23:50 point
The transistor orientation must be related to "strained silicon" which is probably not a feature at your 500nm node...
then you need to get the information from the foundry about the straining orientation.
BTW if you alternate Vdd and Vss, you can alternate/miror the gates instead of wasting the tiny space between them. You have at least miroring in X and Y so 4 versions of the gate, which could be automated somehow...
I should hack a JAvascript manual place&router ;-) JSfloorplan for the win !
omg did I just start another project ?
SHAOS wrote 10/04/2016 at 00:10 point
I have design in "Scalable CMOS" rules which are "foundry-agnostic" so theoretically it could be downgraded as low as 180nm if needed (but I still think it will require some serious modifications).
Yann Guidon / YGDES wrote 10/04/2016 at 00:19 point
Yup, the standard rules taught in schools :-)
I'd like to review your layout one day. And I'll examine your cell library as well. 15 years ago, I fought to go to a university where they developped their own "open source" cell lib...
Yann Guidon / YGDES wrote 10/03/2016 at 19:49 point
The unpacking video is so ... tense ! You are really extremely excited !
SHAOS wrote 10/03/2016 at 22:50 point
of course - it was 1st time :)
Yann Guidon / YGDES wrote 10/03/2016 at 22:56 point
i understand !!!!!
Ted Yapo wrote 10/03/2016 at 17:37 point
This is an amazing idea, a significant step beyond multi-project wafers.  I wonder if it would be possible to multiplex the pins like the PIC's peripheral-pin-select so that designs can share pins - it seems like this could easily become the limiting factor. I could imagine a config register interface that you could write to switch the pins between designs.
Do you have an idea for the approximate cost?
Yann Guidon / YGDES wrote 10/03/2016 at 17:45 point
I have thought about this multiplexing thing, too. I'm in favor but the methodology is probably not yet mature enough.
I/O pins and memory seem to me to be the most limiting factors but it's an excellent sandbox !!!
The cost would be in the range of a few K$ / design but this also depends on what process node is selected for the whole run. 0.5µ is too large and slow, I'd try 0.18 or 0.13µ... But Alex wants things that work at 5V :-/
SHAOS wrote 10/03/2016 at 17:58 point
and 0.5um is cheaper (but 0.35um is close and only a little cheaper if you order more items).
0.13 and 0.18 are more expensive (like x2)
Yann Guidon / YGDES wrote 10/04/2016 at 00:16 point
I'd go for .35µ. Twice the gate density so larger SRAM arrays. How many metal layers ?
I'd also investigate why your design was slow. I'm not a guru but must have at least one or two clues of what could go wrong.
SHAOS wrote 10/04/2016 at 00:29 point
3 metal layers - standard C5 process. It's for 5V, but it's working pretty well up to 20V (and down to 3.5V). I think my problem was filling cell that I came up with (foundry required all empty space filled with something to support neighboring areas) - it looks like it created a lot of parasitic capacitance between signals (and the ground) that ate all dynamic of the circuit...
Yann Guidon / YGDES wrote 10/04/2016 at 00:33 point
I noticed you have a lot of empty space...
SHAOS wrote 10/04/2016 at 00:38 point
it's not empty, it's filled with filling cell...
Yann Guidon / YGDES wrote 10/04/2016 at 00:42 point
I mean "empty" as in "not used", "there's quite a lot of space to populate with operating stuff" :-)
SHAOS wrote 10/04/2016 at 01:00 point
for now yes - it is not so much to test yet, so lets stick with 0.5um ;-)
SHAOS wrote 10/03/2016 at 22:49 point
yes, I multiplexed pins already for bottom-left design (through network of transmission gates) - problem is power lines will be shared in this case, so short circuit in one design may kill whole project
about cost - manufacturer has confidential prices, but anybody can request automatic quote from them and get actual number for the whole DIP40 prototype manufacturing
Yann Guidon / YGDES wrote 10/04/2016 at 00:21 point
Note about multiplexing...
it's a good idea but not ideal.
Now, if you have your own bonding machine, you *could* create way more pads but only populate those required by one particular project. Think about it ! ;-)
SHAOS wrote 10/04/2016 at 00:35 point
Pads are huge and occupy space where a lot of transistors could be located, so it's always tradeoff between number of pads and useful area of the silicon...
Yann Guidon / YGDES wrote 10/04/2016 at 00:41 point
Yup. OTOH your first run is "almost empty" :-P
SHAOS wrote 10/04/2016 at 01:02 point
first run was intended to be packaged by them into DIP40, so there are only 40 pads on the sides (in accordance to their spec).
Yann Guidon / YGDES wrote 10/03/2016 at 17:36 point
Oh and we should get a bonding machine !
SHAOS wrote 10/03/2016 at 17:54 point
yes, it should reduce cost of prototyping (up to $50 per chip).
Yann Guidon / YGDES wrote 10/03/2016 at 22:51 point
I'll let you find it. I've blown away my equipiment budget for this decade.
SHAOS wrote 10/03/2016 at 22:54 point
I found a few used bonders online for not so scary price, but I still can't find source for empty DIP packages...
Yann Guidon / YGDES wrote 10/03/2016 at 23:28 point
The trick is to bond directly to PCB... CoB-like: "chip on board", like in watches, multimeters and other cheap gadgets with a black epoxy blob.
Cheap...
SHAOS wrote 10/03/2016 at 23:34 point
yes, it's doable, but - under "epoxy blob" it could be anything - FPGA, CPLD or even MCU - and haters may say that it is not true full custom :)
Ted Yapo wrote 10/03/2016 at 23:52 point
I bet you could come up with a package design from a few layers of PCB epoxied together that emulated a DIP package pretty well. Three layers might do it - a bottom layer to bond the die to, a middle layer with a central cutout and a ring of pads for bond wire connections, and a top layer with a larger cutout to protect the wires.
SHAOS wrote 10/04/2016 at 00:02 point
Pseudo DIP? May be
K.C. Lee wrote 10/04/2016 at 00:09 point
You already need to have make a PCB, might as well go a bit beyond.  Simply mount a bare die directly (aka black blob) on a breakout PCB.  Decoupling caps, other needed parts and your breakout connectors can be mounted where it is needed.
Yann Guidon / YGDES wrote 10/04/2016 at 00:22 point
@Ted Yapo I love your idea !
SHAOS wrote 10/04/2016 at 00:36 point
@K.C. Lee it's true
Yann Guidon / YGDES wrote 10/03/2016 at 09:03 point
Awesome !
That will be one great way to test #AMBAP: A Modest Bitslice Architecture Proposal :-D
SHAOS wrote 10/03/2016 at 17:53 point
