Currently trying to jump to the last car of efabless train :)
- made a few test designs for TinyTapout that goes with efabless 130nm process;
- and also submitted 2 open source test designs to efabless 1st 180nm process that should go through GlobalFoundries
Nothing fancy, because everything is done through Verilog - you can actually draw your schematics in Wokwi but it's eventually converted to Verilog as well. Good thing is that self-made latches are translated to low level almost as is:
This is a Muller gate (or C-gate) and if it will work as intended on actual chip then it means async designs are very possible with this Yosys driven process :)
nice!
Hi, Matt!
Thank you for TinyTapout :)
Looking forward to participate in TT03 ;)
