razor_blade_single_edge.stepCAD for the razor blade used. Standard 1.5 x 3/4" single edge razor blade. The dimensions in my model match precisely the blades I purchased and are not exactly 1.5 x 3/4 - your blades may vary.step - 63.38 kB - 05/21/2016 at 12:32 |
chamfer_tool_2_piece.zip2 piece body design, includes CAD files (STEP format) and 3d printer files (STL format). This design requires three #4-40 screws and nuts to assemble, but the two piece body is going to be easier to print without support material.x-zip-compressed - 1.01 MB - 05/21/2016 at 12:24 |
chamfer_tool_1_piece.zip1 piece body design, includes CAD files (STEP format) and 3d printer files (STL format). This is for those with a high quality 3d printer, requires no additional hardware to assemble. I had success printing this on a Stratasys with soluble supports, but it probably won't print well on a lower grade printer.x-zip-compressed - 944.56 kB - 05/21/2016 at 12:23 |
