Relay-based projects
A list of projects where the relays are doing some kind of processing or computing - i.e. something more than just switching a load.
If you're into relay logic then you probably already know about many of these projects - but hopefully some are new to you and can give you additional insights and ideas for your own projects.
Hackaday relay projects
YGREC16 - YG's 16bits Relay Electronic Computer
https://hackaday.io/project/18757
(superseded by #YGREC-РЭС15-bis)
SPDT16: 16-bits arithmetic unit with relays
hackaday.io/project/10889
(superseded by the above project)
SPDT16
Kalin-Burkhart Logical Truth Calculator
hackaday.io/project/7871 (project vanished ?)
4 bit relay adder
hackaday.io/project/3802
RISC Relay CPU
hackaday.io/project/11012
Simple Relay ALU
https://hackaday.io/project/162246-simple-relay-alu
Relay Puzzle Box
hackaday.io/project/2075
Swifty's Relay Clock Project
https://hackaday.io/project/55956
Relay Logic Clock
hackaday.io/project/8683
Relay Computer
hackaday.io/project/10303
RelayRepRap
https://hackaday.io/project/11914-relayreprap
Brainfuck relay computer
https://hackaday.io/project/18599-brainfuck-relay-computer
4 bit relay adder
https://hackaday.io/project/3802-4-bit-relay-adder
4-bit Relay ALU (РЦВМ-1)
https://hackaday.io/project/159308-4-bit-relay-alu-1
RELAY COMPUTING
https://hackaday.io/project/163254-relay-computing
R200 Relay Computer
https://hackaday.io/project/160710-r200-relay-computer
Super Micro Relay Computer
https://hackaday.io/project/167895-super-micro-relay-computer
Relay projects on other sites
Harry Porter's Relay Computer
web.cecs.pdx.edu/~harry/Relay
(see the video )
i² (i Squared
isquared.weebly.com
Basic relay computer
electronixandmore.com/projects/relaycomputer
Relay Computer Two
electronixandmore.com/projects/relaycomputertwo
RC-3
computerculture.org/projects/rc3
Zusie
www.nablaman.com/relay
YouTube: https://www.youtube.com/channel/UCxTUNOQS56cvNHgRD5bKMsg
Mercia
relaiscomputer.nl
Relay calculator
simonwinder.com/projects/relay-calculating-engine (broken)
YouTube video of the square rooting machine : https://www.youtube.com/watch?v=gI8luQnyM9A (2014)
Paul Laws's Relay Computer
relaycomputer.blogspot.my
moved to https://relaycomputer.co.uk/
Clicks
clicksrelaycpu.blogspot.my
A fistful of relays
github.com/Dovgalyuk/Relay/wiki/Build-log
Radiolok
rln.nnov.ru/index.php
github.com/radiolok/RelayComputer2
tqfp.org/radiolok/releynaya-evm-versiya-2-releynaya-logika-alu
TIM series
northdownfarm.co.uk/rory/tim
Duo 14 Premium
ostracodfiles.com/ostracod/relay.html
R500/7T
strangecalc.ch
Youtube : https://www.youtube.com/watch?v=67jLony0mXg
Simon relay processor
cs.ubc.ca/~hilpert/e/simon
Relay Trainer
relaysbc.sourceforge.net
Relaiscomputer
relaiscomputer.de/pr.htm
Relaisrechner
schlaefendorf.de/relaisrechner/dokumentation
4-Bit Relay Adder
brainlubeonline.com/relaycomputer/RelayFramer.html
Neodem ALU/Computer
neodem.com/.../relay-computer
TD4 with relays
http://www.geocities.jp/team_zero_three/TD4/
Relay Computer
http://www.xpl0.org/rr6/
More:
Inspirational relay projects
Pongmechanik
cyberniklas.de/pongmechanik
Software for relay projects
TOFU Circuit Simulator
meatfighter.com/tofu
Relayser - Relay logic simulator
github.com/SmallRoomLabs/Relayser
Youtube:
Relay theory & general info
In the news
  • Falstad's Circuijs now has relays !
    Yann Guidon / YGDES06/27/2021 at 21:51 0 comments
    I was trying to simulate my incrementer's new carry logic and noticed a new feature in http://www.falstad.com/circuit/circuitjs.html : configurable relays !
    You can edit the coil's inductance and resistance, the contact's on and off resistances, the coil's on current and the number of contacts. Still missing is the off current so this is not yet ready to simulate hysteresis. I sent a bug/feature request ;-)
    This page already has some links to relay simulators but circuitjs stands on its own and does many things, moderately well but well enough for most cases. I used it a lot to simulate many types of circuits and now even more !
    What else do you think is still missing from circuitjs ?
    (And for those who might wonder, here is the new circuit for the carry logic, using coils in series instead of parallel as in a previous attempt, so now the current is constant for each slice of 4 bits)
    And the link to play at home.
    UPDATE
    Circuitjs now handles hysteresis ! Here's my first test with the experimental code :-) The new features will be soon integrated in the main dev branch.
  • Rory's computer
    Yann Guidon / YGDES09/08/2018 at 09:55 0 comments
    The TIM machine was featured at EMF !
    You too can build your own machine :-)
  • April 1st video
    Yann Guidon / YGDES03/28/2017 at 04:02 2 comments
    Sweet music composed by @Al Williamsl :-)
    Relays are so simple :-)
  • Relay calculators on youtube
    Yann Guidon / YGDES12/11/2016 at 16:51 0 comments
    Covers the early electromechanical calculators :-)
    The Harwell Dekatron / WITCH calculator, uses Dekatron tubes for storage and telephone relays for the rest. The oldest electronic computer that is still working !
    The computational speed is crazy and tested "live" !
    More links welcome !
View all 4 project logs
Mark wrote 03/29/2017 at 00:17 point
I'd like to be on the list.  Relays are a big part of the games I've built with retired electromechanical pinball machine parts.  Thanks.    funwithpinball.com/games
Yann Guidon / YGDES wrote 03/29/2017 at 00:23 point
Welcome here !
will.stevens wrote 03/24/2017 at 22:36 point
Hi, thanks for this great resource, please could you add my project. It's about making the relays from scratch, and then using the relays to make control circuitry:
Yann Guidon / YGDES wrote 03/25/2017 at 01:53 point
Sure ! Thanks for the notice !
Dave Gönner wrote 05/21/2016 at 16:38 point
Can we include this one as well?
http://www.cyberniklas.de/pongmechanik/indexen.html
It's a mechanical implementation of  Pong, with relays for the game logic
matseng wrote 05/22/2016 at 02:47 point
Thanks. I added it in its own section "Inspirational projects" since there was no real technical info like diagrams/schematics and such about the projects, just a BOM.
Still it's a very cool project that I'd love to clone some day - just as I like to build this awesome (non-relay) based mechanical Lunar Lander game some day as well.  http://lushprojects.com/lunarlander/
Yann Guidon / YGDES wrote 05/21/2016 at 14:34 point
Where did you find the background/avatar picture ? I don't remember this one.
matseng wrote 05/21/2016 at 14:50 point
I cheated there a bit. I couldn't find a nice clear picture of an real old relay computer so I took some random picture from an old thelephone exchange instead :)
http://www.bayern-online.com/v2261/artikel.cfm/203/Kennziffernspeicher.html
Yann Guidon / YGDES wrote 05/21/2016 at 14:53 point
relays are also used to control machinery such as elevators :-)
Dave Gönner wrote 05/21/2016 at 14:06 point
Thank you for adding me to this project, I'm honoured to be in such great company. These are all fantastic projects! I hope we can come up with innovative ways of using relays, or at least inspire a relay revival.
matseng wrote 05/21/2016 at 15:40 point
Hopefully it can and will. Or at least we will have use of the collection of projects :-)
I think your project is the most artfully laid out project in the list - especially for being bare pcbs. And also probably is one of the most useful of them as well...
Dave Gönner wrote 05/21/2016 at 16:36 point
Thank you, that is a great compliment. I try to do my best. Functionality and visual appearance are both key considerations.
Yann Guidon / YGDES wrote 05/21/2016 at 12:50 point
Thanks for adding me, Mats, now it's your turn to show us what you can do with relays ;-)
matseng wrote 05/21/2016 at 13:17 point
Still living without hardware :-(  That's why I'm currently hacking away at the last entry in the list - the Relayser.  When it's a bit more ready I can at least dry-run design a system while waiting for getting my stuff out of storage and shipped to a new place. But that is minimum two months away.
