Schematic & BOM
A project log for PIP-Watch
Pip-Watch (Personal Information Panel) is an open-source smart watch with an ePaper display, a bluetooth modem, and a Li-Ion accumulator.
jaraJara 08/24/2014 at 20:280 Comments
I finished a schematic of PIP-Watch Zero, the schematic PDF is on github. I also prepared BOM, which is a basis for a footprint library, and started the PCB layout. The board will be about 80x35mm. The top side will be almost empty, it will only hold buttons and LEDs. Most of the components will be on the bottom side. Battery will be on the top side just under the display.
