ByteThief is essentially a Bus Pirate clone that adds the CAN protocol to the feature set. ByteThief will make use of and extend the ARM port of the Bus Pirate firmware.
Quick Specs:
- STM32F446RET6 STM32 ARM Cortex M4 Microcontroller
- 3.3V DCDC regulator fed by USB port
- 2.54mm spaced shrouded connector
- cable adapters for interfacing with various hardware
- USB interface
- ARM Cortex Debug port
