Adding Video and Indicator Lights to Dashboard
A project log for Clouds Happen
This is a versatile system of hardware and software to evaluate outside weather conditions vs inside weather conditions.
brenda-armourBrenda Armour 06/27/2016 at 17:230 Comments
I spent Sunday improving the Dashboard. I was still interested in streaming live from You Tube. I also wanted to test everything out. So the test subject was me in a motel room with no air conditioning. Its hot and humid and very uncomfortable. I found out that yes you can live stream from the Raspberry Pi camera and after some tweeking had a nice green healthy stream. Below is my live stream from my room. Not too much happening !
You cannot live stream ddirectly from the FreeBoard pane but you can capture the video from your live stream.
