Makown smartwatch
Smartwatch platform for makers
Another smartwatch project inspired by many other DIY watch projects and market trends.
Main goal:
Make open hardware smartwatch platform. Case for building by your 3D printer or CNC router. PCB which you can etch at home by various methods. Programming in Arduino IDE or your favorite IDE with C/C++. All from programming to case construction, designed for easiest way to build it. This will give opportunities for creating your own watch with your set of sensors, functions.
Summary of features:
  • Time
  • BLE-communication
  • 1 week long battery life
  • Full wireless (battery charging too)
  • IP54 standard case
P.S.
Full repository of all project files will be uploaded on github under GPLv3 license
  • 1 × HM-11 BLE module
  • 1 × STM32L051K8 Main core
  • 1 × UG-2828GDEDF11 1.5" uOLED display
  • Still alive
    Ilyas Akhmetzyanov06/28/2016 at 18:05 0 comments
    I was very busy on my main job for a last few weeks, but project still alive and going on!
    In race for smaller size, lower power consumption and what I found at local market, I failed in my idea with easy replicable design, because accelerometer manufactured in LGA16 package, that a little tricky for soldering.
    Now work in progress:
    - pcb design
    - firmware for MCU
  • Anything Goes
    Ilyas Akhmetzyanov05/29/2016 at 20:01 0 comments
    This were very busy weekend, but I worked hard, and now we have repository on Github with 3D files and Manifest file, which explain why I do this project.
  • 3D model
    Ilyas Akhmetzyanov05/29/2016 at 12:31 0 comments
    Today I made 3D model of the watches. Pictures here. I have uploaded files in .STL and .IGES
    Now you can see main feature in design - buttons on top and bottom of the case. In my opinion, this more user friendly position.
  • Designer problems
    Ilyas Akhmetzyanov05/25/2016 at 18:52 0 comments
    Today after few hours of brainstorm, I have a vision of the watch case. First 3D models you can see at the pictures. Now I thinking about rectangular forms with rounded edges. Early I planned to make watches round, but all displays what was found on the market have big frames around active area. In this reason, round case must be a bigger and small active area looks a little "clumsy".
  • Starting point
    Ilyas Akhmetzyanov05/24/2016 at 19:45 0 comments
    Anything goes, work in progress. I design a case and pcb in same time. This is a bit tricky, but not less interesting. At the start of the project I planned to use TFT display, but few days ago my decision is changed. Better to use uOLED display, because it help to reduce power consumption in monochrome mode.
View all 5 project logs
elufa wrote 09/06/2016 at 05:13 point
You can make a bracelet and manage smart home devices
