Case Design
A project log for Frostbite Detector and Alarm
A small pocketable or wearable device that can warn the user of prolonged exposure to cold conditions.
caleb-hannemanCaleb Hanneman 05/29/2016 at 22:240 Comments
In this phase of the project I am designing an enclosure to 3D print for the project. The device is meant to be pocketable and a bare PCB does not fit the bill. The design work is being done in Autodesk Fusion 360. The measurements of the PCB are a follows:
STL Files and CAD files can be found in the files section of the project.
