Implementation
A project log for A4988 Stepper Driver Duplicator
Putting two steppers on a single driver is dumb. Four doubly so. Here's a stepper driver breakout.
benchoffBenchoff 05/26/2016 at 14:270 Comments
here are two parts to this project: a board that takes the step, direction, and enable pins from a socket meant for an A4988 stepper motor driver, and a second board that fans it out to four separate A4988 motor drivers.
Here's the cable adapter:
Simple enough, and uses very common 2x3 ribbon connectors.
The second board drives four A4988 motor controllers with all the requisite hardware. These boards are combined into a single PCB for ease of ordering.
It's designed to connect to stepper motors and a power supply through screw connectors.
And the relevant parts of the schematic:
