Working on Adding an Ultrasonic Distance Sensor to Bit to help with Wall Avoidance
A project log for Bit the RoboDawg
A loving family robot dog
orlando-hoilettOrlando Hoilett 06/02/2016 at 11:530 Comments
Trying to find the best way to mount it. Right now it's being supported by a piece of foam taped to the back of the RoboDawg. Probably need something a little more sturdy.
The idea is to use the distance sensor mounted on a servo motor as a type of sonar system.
