A better bidirectional movement mechanism
A project log for RelayRepRap
This project is about exploring whether it is possible to make a RepRap control system that can be made by a RepRap.
willstevenswill.stevens 09/13/2016 at 23:102 Comments
This video shows the mechanism that I thought about using Lego a couple of days ago:
It seems to have several advantages over the platform mechanism that I posted in an earlier log entry. The main advantage is that both motors are at one end, which will make it possible to have two perpendicular axes without the motors getting in the way. It is also easier to tension the thread - this can be done simply by adjusting the position of the steel rod at the end of the rails.
Below is a diagram that helps to explain how it works.
Matt Moses wrote 09/20/2016 at 22:06 point
Hi Will, you may already be planning something like this, but I drew up a way you could add a second axis to this system. Kind of like a corexy or hbot arrangement, except using four uni-directional motors instead of two bi-directional motors.
It doesn't look like drawings can be embedded in comments, so here is a link where the image is at:
http://imgur.com/a/ejnbR
will.stevens wrote 09/22/2016 at 05:01 point
Thanks Matt, that's really helpful - I had hoped that something like that was possible, but hadn't figured out how to do it
