Min Update
A project log for Home automation on the cheap
Using an esp8266, arduino nano, a salvaged usb power supply, and a couple relays you can automate anything
thjubeckthjubeck 08/08/2016 at 03:250 Comments
If everything is working correctly, this is how the webpage should look. Note the fan icon is animated when on and the lights have two states as well.
