Wireless Programming
A project log for Home automation on the cheap
Using an esp8266, arduino nano, a salvaged usb power supply, and a couple relays you can automate anything
thjubeckthjubeck 09/19/2016 at 05:150 Comments
For wireless programming/re-programming, I connect to the esp using hardware virtual serial port found here.
Be sure to disable NVT in the settings or you will not be able to program the controller.
