Radar ultrasonico arduino programa disponível
utilizando o sensor de Ultrasónico, servo motor
plataforma Arduino mega , Uno ,Nano .
Using Arduino Ce Processing supply 5 v and computer screen, we come to a submarine aircraft tanks of technology.
or pays or contributes Razao social Jose Pedro Rodrigues do Amaral Ribeiro
IBAN BR190036 0305 0392 1000 1101 343C 1
Agencia 3921
Operaçao 001
Conta DV 001110134-3
Codigo SWIF CEFXBRSP
Autor :Jose Pedro R. A. Ribeiro
Data :27/05/2016
Arduino versão 1.6.7
#include <Servo.h> //
Servo leftRightServo; //
int leftRightPos = 0; //
int index = 0; //
long total = 0; //
int average = 0; //
long duration = 0; //
int distance = 0;
// CONFIGURACIÓN:
int echoPin = 53; //
int trigPin = 51; //
int servoPin = 12; //
int servoMin = 700; //
int servoMax = 2400; //
const int numReadings = 2; //
void setup() {
leftRightServo.attach(servoPin,700,2400); //
Serial.begin(9600); //
pinMode(trigPin, OUTPUT); //
pinMode(echoPin, INPUT); //
digitalWrite(trigPin, LOW); //
void loop() {
for(leftRightPos = 0; leftRightPos < 180; leftRightPos++) { //
leftRightServo.write(leftRightPos);
for (index = 0; index<numReadings; index++) { //
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH, 17400); //
if (!duration){ //
duration = 17400; //
distance = duration/58; //
total = total + distance; //
delay(50); //
average = total/numReadings; //
total = 0; //
Serial.print("X"); //
Serial.print(leftRightPos); //
Serial.print("V"); //
Serial.println(average); //
for(leftRightPos = 180; leftRightPos > 0; leftRightPos--) { //
// Pulso de 10us para inicial el modulo
if (!duration){
duration = 17400;
delay(50);
total = 0;
Serial.print("X");
Serial.print("V");
Autor: Jose Pedro R. A. Ribeiro
Radar Ultrasonico
Processing 3.1.1
Data 27/05/2016 .
import processing.serial.*; //
Serial myPort; //
float x, y; //
int radius = 350; //
int w = 300; //
int degree = 0; //
int value = 0; //
int motion = 0; //
int[] newValue = new int[181]; //
int[] oldValue = new int[181]; //
PFont myFont; //
int radarDist = 0; //
int firstRun = 0; //
int lf = 10; //
void setup(){
size(750, 450); //
background (0); //
myFont = createFont("verdana", 12); //
textFont(myFont); //
println(Serial.list()); //
myPort = new Serial(this,"com7", 9600); //
myPort.bufferUntil(lf); //
/* draw the screen */
void draw(){
fill(0); //
noStroke(); //
ellipse(radius, radius, 750, 750); //
rectMode(CENTER); //
rect(350,402,800,100); //
if (degree >= 179) { //
motion = 1; //
if (degree <= 1) { //
motion = 0; //
/* setup the radar sweep */
We use trigonmetry to create points around a circle.
So the radius plus the cosine of the servo position converted to radians
Since radians 0 start at 90 degrees we add 180 to make it start from the left
Adding +1 (i) each time through the loops to move 1 degree matching the one degree of servo movement
cos is for the x left to right value and sin calculates the y value
since its a circle we plot our lines and vertices around the start point for everything will always be the center.
strokeWeight(7); // set the thickness of the lines
if (motion == 0) { // if going left to right
for (int i = 0; i <= 20; i++) { // draw 20 lines with fading colour each 1 degree further round than the last
stroke(0, (10*i), 0); // set the stroke colour (Red, Green, Blue) base it on the the value of i
line(radius, radius, radius + cos(radians(degree+(180+i)))*w, radius + sin(radians(degree+(180+i)))*w); // line(start x, start y, end x, end y)
} else { // if going right to left
for (int i = 20; i >= 0; i--) { // draw 20 lines with fading colour
stroke(0,200-(10*i), 0); // using standard RGB values, each between 0 and 255
/* Setup the shapes made from the sensor values */
noStroke(); // no outline
/* first sweep */
fill(0,50,0); // set the fill colour of the shape (Red, Green, Blue)
beginShape(); // start drawing shape
for (int i = 0; i < 180; i++)...
SG90Servo.pdf
SG90 DETALHES
Adobe Portable Document Format - 125.09 kB - 05/28/2016 at 02:06
Preview
Download
  • 1 × SENSOR ULTRASONICO 5V 4 SAIDAS
  • 1 × PLACA ARDUINO UNO,MEGA,NANO
  • 1 × SERVO SG90
  • 1 × SUPORTE SERVO
  • 1 × FONTE DC 5V
View all 6 components
  • Segunda Versao Super tecnologica
    Jose Pedro R. A. Ribeiro05/29/2016 at 01:13 0 comments
    //Autor Jose Pedro R. A. Ribeiro josepedrofederal@yahoo.com.br 28/05/2016 Processing 3.1.1
    Serial myPort;
    int time, i, currentServoAngle, k, m, ANGLE, DISTANCE;
    float ANGLE_RAD;
    float x, y;
    float[] x_mem=new float[200];
    float[] y_mem=new float[200];
    float[] x_width =new float[200];
    float[] y_width =new float[200];
    int CHECK_ANG_INT;
    int CHECK_SON_int;
    int OBJECT_WIDTH = 4;
    PFont Font1;
    void setup() {
    size(800, 400);
    Font1 = createFont("Times New Roman Bold", 16);
    smooth();
    myPort = new Serial(this, "COM8", 115200);
    translate(400, 400);
    void draw_background()
    background(0, 30, 30);
    fill(0, 102, 51);
    textFont(Font1);
    text("Arduino Radar processing 3.1.1", 10, 30);
    fill(0, 51, 0);
    arc(400, 400, 800, 800, PI, 2*PI, CHORD);
    noFill();
    stroke(0, 251, 32) ;
    arc(400, 400, 700, 700, PI, 2*PI, CHORD);
    noFill();
    arc(400, 400, 600, 600, PI, 2*PI, CHORD);
    noFill();
    arc(400, 400, 500, 500, PI, 2*PI, CHORD);
    noFill();
    arc(400, 400, 400, 400, PI, 2*PI, CHORD);
    noFill();
    arc(400, 400, 300, 300, PI, 2*PI, CHORD);
    noFill();
    arc(400, 400, 200, 200, PI, 2*PI, CHORD);
    noFill();
    arc(400, 400, 100, 100, PI, 2*PI, CHORD);
    line(400, 400, 400, 0);
    line(400, 400, 25, 250);
    line(400, 400, 775, 250);
    line(400, 400, 115, 115);
    line(400, 400, 685, 115);
    line(400, 400, 235, 35);
    line(400, 400, 565, 35);
    void draw() {
    draw_background();
    String INPUT_ANGLE = myPort.readStringUntil('*');
    String INPUT_DIST = myPort.readStringUntil('^');
    if (INPUT_ANGLE != null) {
    INPUT_ANGLE = INPUT_ANGLE.replaceFirst("\\*", "");
    ANGLE=int(INPUT_ANGLE);
    ANGLE_RAD=radians(ANGLE);
    currentServoAngle=ANGLE;
    if (INPUT_DIST != null) {
    INPUT_DIST = INPUT_DIST.replaceFirst("\\^", "");
    DISTANCE=int(INPUT_DIST);
    DISTANCE=DISTANCE*5;
    if (1 == 1)
    if (DISTANCE>=300) {
    // Large distance object need not be plotted
    DISTANCE= 0;
    println(DISTANCE);
    println(currentServoAngle);
    i=i+10;
    x=DISTANCE*cos(ANGLE_RAD);
    text(400+x, 10, 60);
    y=DISTANCE*sin(ANGLE_RAD);
    text(400-y, 10, 80);
    x_mem[currentServoAngle]=400+x;
    y_mem[currentServoAngle]=400-y;
    if (DISTANCE < 300 )
    x_width[currentServoAngle] = 400 + ((DISTANCE + OBJECT_WIDTH)*cos(ANGLE_RAD));
    y_width[currentServoAngle] = 400 - ((DISTANCE + OBJECT_WIDTH)*sin(ANGLE_RAD));
    } else {
    x_width[currentServoAngle] = x_mem[currentServoAngle];
    y_width[currentServoAngle] = y_mem[currentServoAngle];
    // if (DISTANCE<400)
    for (k=0; k<180; k++)
    stroke(127, 255, 0);
    fill(127, 255, 0);
    ellipse(400, 400, 4, 4);
    ellipse(x_mem[k], y_mem[k], 4, 4);
    ellipse(x_width[k], y_width[k], 4, 4);
    //line(x_width[k], y_width[k], x_mem[k], y_mem[k]);
    if (i>800) {
    i=0;
    noFill();
    stroke(255, 0, 51) ;
    arc(400, 400, i, i, PI, 2*PI, CHORD);
    arc(400, 400, i-1, i-1, PI, 2*PI, CHORD);
    arc(400, 400, i-2, i-2, PI, 2*PI, CHORD);
    arc(400, 400, i-3, i-3, PI, 2*PI, CHORD);
    arc(400, 400, i-4, i-4, PI, 2*PI, CHORD);
    //lembre se veja qual porta serial que esta no ide arduino defina placa e porta .no caso porta serial "COM8".Coloque a sua no programa linha 19
  • sensor ultrasônico HC-SRO4
    Jose Pedro R. A. Ribeiro05/28/2016 at 19:43 0 comments
    O sensor ultrasônico HC-SR04 funciona como um detector de objetos e permite medir distancias mínimas de 2 centímetros podendo chegar a distancias máximas de até 4 metros com uma precisão de 3 milímetros. Estes sensores emitem um sinal ultrassônico (40 kHz) que ao atingir um objeto, retorna ao sensor. O sinal de retorno é captado, permitindo-se calcular a distância do objeto ao sensor, medindo o tempo de ida e volta do sinal emitido.
    Usando a seguinte fórmula, é possível calcular a distância, sendo que v (velocidade do som) é ~350m/s.
    d[m] = ( v[m/s] * t[s] ) / 2
    Para a contagem do tempo, foi utilizado o Timer1, configurado de modo que incremente a cada 1us.
View all 2 project logs
Jose Pedro R. A. Ribeiro wrote 05/28/2016 at 12:40 point
As pessoas pode tambem  aprender português
termos técnicos são de fácil compreensão.
vou refletir sobre sugestão .
