Fritzing is really cool
A project log for E-Zpass Privacy Automation
a project to be in control and notified of what the EZpass is exactly doing in that suspicious little white box
jordanJordan 07/07/2016 at 05:542 Comments
So I've never played with Fritzing befoer, and its a very cool program. I laid out my breadboard and it then guide me through creating a schematic... its functionally correct, but i'm going tto make my own so the interconnects are a bit more logical, and then it even creates a 2 sided pcb of the project for you, kind of, you have to lay it out, but the autotrace function is pretty sweet.
Its very cool, and the Fritzing graphic has been added in the project.
I really like the PCB option, and its tempting, but i want to see what it would take to breakout the GPS module before i commit to having a PCB made, SIngle shot PCB's are expensive, worth it for a great, functional project, but at $30 a pop or higher, is not cheap.
deʃhipu wrote 06/29/2017 at 08:29 point
Hint: you can change the colors of the wires for better readability.
Arya wrote 06/29/2017 at 04:05 point
You can also export the PCB out of Fritzing and then get it made for much cheaper than Fritzing offers =)
