• OS/J5 running on SAM S70
    jeff • 06/22/2016 at 04:19 • 0 comments
    it is not quite right, but enough is working to boot OS/J5
  • YAY!
    jeff • 06/16/2016 at 04:37 • 2 comments
    bossac successfully hacked.
    blinky.c successfully loaded.
    LED is blinking!
  • obstacle...
    jeff • 06/16/2016 at 00:14 • 0 comments
    board appears to work.
    the SAM-BA boot rom runs, the usb port is recognized,
    I can manually connect and enter cryptic SAM-BA commands.
    chip is not supported by bossac though, so cannot program it, yet.
    % emacs bossac.cpp
  • assembled
    jeff • 06/16/2016 at 00:05 • 1 comment
    board assembled.
  • suggestions?
    jeff • 05/28/2016 at 18:14 • 1 comment
    board is not finished yet, and there is still a little space on the board.
    feature requests?
  • ethernet?
    jeff • 05/28/2016 at 18:08 • 2 comments
    the SAM E70 has a compatible pinout and has ethernet.
    is wired ethernet interesting?
  • usb high-speed
    jeff • 05/28/2016 at 18:07 • 1 comment
    I was looking for a small fast ARM board, with a high-speed (480MHz) USB.
