The CAT Is Out Of The Bag.
A project log for Affordable Reflectance Transformation Imaging Dome
A simple and inexpensive way to image and analyze subtle surface details on objects.
leszek-pawlowiczLeszek Pawlowicz 11/05/2022 at 19:330 Comments
ON Semiconductor, the maker of the CAT4101 LED driver that is a critical component of this system, has discontinued this item. So, as of now, this project is no longer practical. I am looking for an acceptable substitute, but as of yet have not found one. There are alternative approaches to creating an RTI dome, some of which are far simpler than the one outlined here, but each has a set of drawbacks. If I come up with a reasonable solution, I'll post it here.
