10-bit Component-less Volume Control for Arduino!
Back to project overview
Using PWM at an ultrasonic frequency, I've given Arduino 10-bit volume control for Tone() generation using nothing but the speaker.
755zwz09 wrote 03/06/2019 at 01:28 point
How do you stop the sound from playing.
I tried to stop the sound with noTone but it kept playing. I figured out you can stop it by setting the volume to 0 but that doesn't work for the project i'm doing.
napo7 wrote 06/13/2016 at 13:21 point
Awesome !
I need such a thing to drive a speaker (to be a metronome) on a DIY eDrum.
I'd like to drive it via a transistor , to allow more current than the 20mA allowed by the Atmega ? Is that possible ?
Lixie Labs wrote 06/13/2016 at 18:47 point
Should be fine! The high-speed PWM frequency used is 62,500Hz, which is higher than your hearing range, and lower than the upper limits of most transistors. :)
