Wenn ist das Nunstück git und Slotermeyer? Ja! Beiherhund das Oder die Flipperwaldt gersput!
A project log for documentation screenshots
While datasheets are made by humans
jaromirsukubajaromir.sukuba 12/17/2016 at 15:132 Comments
Just a tiny reminder that Siemens MCU guys were probably located in Germany, back in the 90's. In case control logik is not enough for you, there you have schadow latch.
Source: SAB805x7 datasheet: http://www.keil.com/dd/docs/datashts/infineon/80c5x7_um.pdf
Yann Guidon / YGDES wrote 12/17/2016 at 20:12 point
Wie schade... ow...
davedarko wrote 12/17/2016 at 18:21 point
