Is this the place to post code? Who cares, here it is, respectfully stolen of the net and tweaked to suit my own fiendish desires, a lot of the old stuff is in there from the original code and lots of test code slashed out, man alive i cut corners! My coding is nearly as messy as my workshop :) It should compile on an arduino.
Here is the Transmitter code;
#include <Servo.h>
#include <JeeLib.h>  //from jeelabs.org
#include <Wire.h>
//#include "nunchuck_funcs.h"
#define myNodeID 10          //node ID of tx (range 0-30)
#define network     210      //network group (can be in the range 1-250).
#define freq RF12_868MHZ     //Freq of RF12B can be RF12_433MHZ, RF12_868MHZ or RF12_915MHZ. Match freq to module
byte byteRead;
typedef struct // create structure - a neat way of packaging data for RF comms
  int jx, jy, acy, acx, zButton, cButton; // data from the controller. these have to match.
PayloadTX;
PayloadTX wiichuck;
byte accx,accy,zbut,cbut,joyx,joyy; // names of the nunchuck data
// constants won't change. They're used here to
// set pin numbers:
const int right = 4;     // the number of the pushbutton pin
const int backward = 5;
const int forward = 6;
const int left = 7;
int p = 0;
int t = 0;
int r = 0;
int potpin0 = 5;
int potpin1 = 4;
int potpin2 = 3;
int val0;
int val1;
int val3;
//const int ledPin =  13;      // the number of the LED pin
// variables will change:
//int buttonState = 0;         // variable for reading the pushbutton status
int Right = 0;
int Backward = 0;
int Forward = 0;
int Left = 0;
//int cbut = 0;
void setup() {
  // initialize the LED pin as an output:
 // pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  rf12_initialize(myNodeID,freq,network);
  Serial.begin(9600);
  pinMode(right, INPUT);
  pinMode(backward, INPUT);
  pinMode(forward, INPUT);
  pinMode(left, INPUT);
//  accx = 90;
//  accy = 90;
//  zbut = 90;
  //Stuff here for reading the three pots.
void loop(){
      Serial.print(" 1pan ");
  Serial.print(accx);
//  Serial.print("\n");
  Serial.print(" 1tilt ");
  Serial.print(accy);
  Serial.print(" 1raise ");
  Serial.print(zbut);
  Serial.print("\n");
  p = analogRead(potpin0);            // reads the value of the potentiometer (value between 0 and 1023)
  accx = map(p, 0, 1023, 0, 179);     //
  t = analogRead(potpin1);            // reads the value of the potentiometer (value between 0 and 1023)
  accy = map(t, 0, 1023, 0, 179);     //
  r = analogRead(potpin2);            // reads the value of the potentiometer (value between 0 and 1023)
  zbut = map(r, 0, 1023, 0, 179);     //
  // read the state of the pushbutton value:
  Right = digitalRead(right);
  Backward = digitalRead(backward);
  Forward = digitalRead(forward);
  Left = digitalRead(left);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  //LEFT
  //Serial.print(cbut);
  //Serial.print("cbut val\n");
  Serial.print(" pan ");
  Serial.print(accx);
  Serial.print(" tilt ");
  Serial.print(accy);
  Serial.print(" raise ");
  Serial.print(zbut);
  Serial.print("\n");
  if (Left == HIGH) {
    // turn LED on:
    Serial.print("left\n");
    cbut = 4;
    //digitalWrite(ledPin, HIGH);
  else if (Forward == HIGH) {
    // turn LED on:
    Serial.print("forward\n");
    cbut = 1;
  //BACKWARD
  else if (Backward == HIGH) {
    // turn LED on:
    Serial.print("Back\n");
    cbut = 2;
  //BACKWARD
  //RIGHT
  else if (Right == HIGH) {
    // turn LED on:
    Serial.print("right\n");
    cbut = 3;
  else {
    cbut=0;
    // turn LED off:
    //Serial.print("right off\n");
    //digitalWrite(ledPin, LOW);
  //RIGHT
  //cbut = 1;// nunchuck_cbutton();
  //accx  = 71; //nunchuck_accelx(); // ranges from approx 70 - 182
  //accy  = 65;// nunchuck_accely(); // ranges from approx 65 - 173
  //zbut = 2;//nunchuck_zbutton();
  joyx = 3;//nunchuck_joyx();
  joyy = 4;//nunchuck_joyy();
  wiichuck.jx = joyx; // read wii angle and store value
  //wiichuck.jx = map(wiichuck.jx, 30, 220, 0, 179); // map the joystick data for servo use
  wiichuck.jy = joyy;
  //wiichuck.jy = map(wiichuck.jy, 30, 220, 0, 179);
  wiichuck.acy = accy;
  wiichuck.acx = accx;
  //wiichuck.acx = map(wiichuck.acx, 65, 173, 135, 45); // mapp the accelerometer data to drive the car
  wiichuck.cButton = cbut;
  wiichuck.zButton = zbut;
  int i = 0;
  while (!rf12_canSend() && i<10)
    rf12_recvDone();
    i++;
  rf12_sendStart(0, &wiichuck, sizeof wiichuck);
  //Servo control
  //Pan number = reading from pot and so on.
 //transmit pan number.
  delay(20);
Here is the code for the receiver, pumping out commands to two drive motors and three servos.
#include <Servo.h>
//credit for RFM12B code from
//Glyn Hudson openenergymonitor.org GNU GPL V3 12/4/12
//Credit to JCW from Jeelabs.org for RFM12
#include <JeeLib.h>
#define myNodeID 30          //node ID of Rx (range 0-30)
typedef struct
  int jx, jy, acy, acx, zButton, cButton; // this is the data from the controller. they must match.
PayloadTX;
PayloadTX wiichuck;   // the payload, named wiichuck
Servo CamRaise;
Servo CamTilt;
Servo CamPan;
const int wiichuck_NodeID=10;            //emonTx node
//Servo steerServo;
//int servopin1=9;
int steer = 90;
int joyx; // Joystick X axis
int joyy; // joystick Y axis
int accy; // Accelerometer Y axis
int acyf; // Forward
int acyr; // Reverse
int accx; // Accelerometer X axis
int M2; // Accelerometer X axis
int M1; // Brake function
int whatever; // i never used this for anything, but it's here
int motor1L=6; // output to motor driver
int motor1R=7; // output to motor driver
int motor2L=8; // output to motor driver
int motor2R=9; // output to motor driver
int counter=0; // counter for brake function
// maybe......
int pan;
int tilt;
int raise;
int one;
void setup() {
  rf12_initialize(myNodeID,freq,network);   //Initialize RFM12 with settings defined above
  Serial.begin(9600);
  //  Serial.println("RF12B demo Receiver - Simple demo"); //pointless memory waste
  //  Serial.print("Node: ");                              // but i keep it all here
  //  Serial.print(myNodeID);                              // just in case
  //  Serial.print(" Freq: ");                             // something screws up
  //  if (freq == RF12_433MHZ) Serial.print("433Mhz");
  //  Serial.print(" Network: ");
  //  Serial.println(network);
  //steerServo.attach(servopin1);
  //steerServo.write(steer);
  CamRaise.attach(3);
  CamTilt.attach(4);
  CamPan.attach(5);
  pinMode(motor1L, OUTPUT); // drive forward output pin 5
  pinMode(motor1R, OUTPUT); // drive forward output pin 6
  pinMode(motor2L, OUTPUT); // drive reverse output pin 7
  pinMode(motor2R, OUTPUT); // drive forward output pin 5
  M1 = 0;
  M2 = 0;
  digitalWrite(motor1L, LOW);
  digitalWrite(motor1R, LOW);
  digitalWrite(motor2L, LOW);
  digitalWrite(motor2R, LOW);
void loop() {
  if (rf12_recvDone()){
    if (rf12_crc == 0 && (rf12_hdr & RF12_HDR_CTL) == 0) // i have no idea what this does but i guess its important
      int node_id = (rf12_hdr & 0x1F);		  //extract nodeID from payload
      if (node_id == wiichuck_NodeID)  {             //check data is coming from node with the corrct ID
        wiichuck=*(PayloadTX*) rf12_data;            // Extract the data from the payload
        //joyx = wiichuck.jx;
        //joyy = wiichuck.jy;
        //accy = wiichuck.acy;
       // pan = wiichuck.jx;
        //tilt = wiichuck.jy;
        //raise = wiichuck.acy;
        //accx = wiichuck.acx;
        M2 = wiichuck.acx;
        M1 = wiichuck.cButton;
        one = wiichuck.jx;
        whatever = wiichuck.jy;
        tilt = wiichuck.acy;
        pan = wiichuck.acx;
        raise = wiichuck.zButton;
//set motor outputs to zero
        //Serial.print("C button ");
        //Serial.print(M1);
  //      Serial.print(" jx incoming ");
    //    Serial.print(pan);
      //  Serial.print("..... ");
        //Serial.print(" jy incoming ");
        //Serial.print(tilt);
        //Serial.print("..... ");
        Serial.print(" tilt acy  ");
        Serial.print(tilt);
        Serial.print(" pan acx ");
        Serial.print(pan);
        Serial.print(" raise zbutton  ");
        Serial.print(raise);
                Serial.print(".....\n ");
        CamRaise.write(raise);                  // sets the servo position according to the scaled value
        //delay(15);
        CamPan.write(pan);                  // sets the servo position according to the scaled value
        //delay(15);
        CamTilt.write(tilt);                  // sets the servo position according to the scaled value
        delay(15);
        if(M1 == 1) // Forward
          Serial.print(" Forward \n ");
          digitalWrite(motor1L, HIGH);
          digitalWrite(motor1R, HIGH);
          digitalWrite(motor2L, HIGH);
          digitalWrite(motor2R, HIGH);
        else if(M1 == 2) // Backward
          Serial.print(" Backward \n ");
        else if(M1 == 3) // rotate CW
          Serial.print(" CW \n ");
          digitalWrite(motor1L, HIGH);//m1 forward
          digitalWrite(motor2L, HIGH);//m2 backward
        else if(M1 == 4) // Rotate ccw
          Serial.print(" CCW \n ");
          digitalWrite(motor1L, HIGH);//m1 backward
          digitalWrite(motor2L, HIGH);//m2 forward
        else if(M1 == 5) // m1 forward
          Serial.print(" M1Forward \n ");
        else if(M1 == 6) // m1 backward
          Serial.print(" M1Backward \n ");
        else // stop
          //Serial.print(" stop \n ");
        if(counter == 0 || counter == 2) // turn on the brake
          //digitalWrite(motorpos, HIGH);
          //digitalWrite(motorneg, HIGH);
          //steerServo.write(90); //centers steering
        else
          acyf = map(accy, 110, 177, 30, 255); // remaps the accelerometer readings for driving forward
          acyr = map(accy, 100, 70, 30, 200); // reverse
          if(accy > 110 && accy <182) // Drive forward!
            //forward
            //digitalWrite(motorneg, LOW);
            analogWrite(3, acyf); // speed
          if(accy < 100) // Reverse!
            //backward
            //digitalWrite(motorpos, LOW);
            analogWrite(3, acyr);   //speed
//          if(accy > 100 && accy < 110 || brake == 1)  //if the accelerometer is inbetween the forward and reverse, dont do anything.
//            //digitalWrite(motorpos, LOW);
//            //digitalWrite(motorneg, LOW);
//            steerServo.write(90); //centers steering
//          else
//            steerServo.write(accx); //steering control
        if(counter==2) //resets counter
          counter=0;
  // used for testing
  //Serial.print("JX Axis: "); //not necessary
  //Serial.println(wiichuck.jx);
  //Serial.print("JY Axis: "); //not necessary
  //Serial.println(wiichuck.jy);
  //Serial.print("YF Speed: "); //not necessary
  //Serial.println(acyf);
  //Serial.print("YR Speed: "); //not necessary
  //Serial.println(acyr);
  //Serial.print("X Axis: "); //not necessary
  //Serial.println(wiichuck.acx);
  //Serial.print("C Button: "); //not necessary
  //Serial.println(wiichuck.cButton);
  //Serial.print("Z Button: "); //not necessary
  //Serial.println(wiichuck.zButton);
