This project is the experimental continuation of the #Coffee Maker Delta 3D Printer, aiming for greater build volume and finer print resolution.
Initial improvements include longer arms for greater build volume and gearing down the motors 5:1. More improvements to follow.
This project is slated for an eventual collaboration with the #Mechaduino project, bringing you a 3D printer with closed loop true delta style kinematics. That's right: no more skipped steps, no more endstops.
Swaleh Owais
RenierM
Kenneth
Hi, could you say something about the firmware you use?
Thanks!
