Box for the motor is made of 10 mm laser cut steel plates.
Tires needed to be mended before being able to move it.
We attached a DeWalt XR accu drill to the main shaft in order to move it - it actually worked!
Cut out the sheet metal ( 12 mm steel ) for the outer battery compartment.
And even with a hefty load of lead-acid cells, the weight can only benefit a tractor! Let's see it in action!
