Relaunching the project
A project log for UD-Alert
This undress alert is for my thirteen-year-old son suffering from autism
alain-mauerAlain Mauer 09/01/2019 at 12:060 Comments
We still have the problem and now it's really time for this project. Even if it sounds not complicated, I had first to learn a little bit more about Arduino programming and to understand the fuse bits and boot-loader stuff.
The Digitump Attiny has the fusebit set to lock the pin 5. This pin is needed for ISP programming. So I used this Instructable "Fuse Reset Attiny" to reset the fusebits with 12V.
After the reset , I could finally upload a 1Mhz Boolloader and I make the Digistump run on 3V
Here my quick and dirty fuse bit reset'er.
