Status Update After A Clean Room Week
A project log for UD-Alert
This undress alert is for my thirteen-year-old son suffering from autism
alain-mauerAlain Mauer 09/11/2019 at 06:430 Comments
As mentioned in the title, yeah, it works.So what are the first Results:Each time the pants were removed, the system informed us.Two times, it did not work, but I saw it on the camera, so nothing happened. First, I thought, that there is a problem with the transmission, so I installed a second receiver near the room, but this was not the problem.
It's a mechanical problem. When he removes the pants, with the left hand at the back, the tension to activate the switch is too weak. It's not really a problem, because 10 times out of twelve it worked.
I've already started to build the portable receiver. It won't win a beauty contest, but it works.
Working now on the enclosure and a clean wiring. Will update the receiver part in the "BUILD INSTRUCTIONSafter that.
