The Big One
You know that Rocket in Toy Story that almost blows Buzz and Woody Straight to hell? Want to 3D Print your own? Here you GO! oh it flys too!
avrAVR
3D Printable Flying Model Rocket based on the Toy Story rocket called the BIg One.
The Big One is a flying model rocket version of the rocket seen in the movie Toy Story. The Fins and mounting are printed as one piece as is the nose cone. The parts are designed for a Quest Aerospace 50mm tube (cardboard), that can be purchased from them directly. The engine mounting setup is also going to printed with the exception of a cardboard tube for holding the engine, the mount will be printed out of heat tolerant plastic.
Specs:
- 3D Printed Nose Cone
- 3D Printed Fin Body w/ Launch lug
- 50mm Quest Aerospace Body Tube
- 25mm Quest Aerospace Engine Tube
- 3D Printed Engine Mounting System
- C/D/E Engine Sizes
- Quest Aerospace Paraschute
Fin Body - Fin-Body.step
Fin Body update with Launch Lug as STEP Model
step - 108.73 kB - 06/04/2016 at 07:09
Download
Cone - NoseCone.step
STEP model of Cone
step - 38.57 kB - 06/04/2016 at 07:09
Download
Dummy Tube - Dummy Tube.step
DUmmy Tube Step model
step - 8.50 kB - 06/04/2016 at 07:09
Download
Part Studio 1 - Fin-Body.stl
First Prototype Fin Body, it doesn't have a launch lug integrated in it, might be good for people not wanting to build a flying rocket.
Standard Tesselated Geometry - 17.56 kB - 06/04/2016 at 06:56
Download
Cone - NoseCone.stl
Rocket nose cone.
Standard Tesselated Geometry - 648.71 kB - 06/04/2016 at 06:56
Download
  • Some Parts Designed and Prototyped
    AVR06/04/2016 at 07:23 0 comments
    So, growing up I loved building model rockets, I've always wanted one like the one in Toy Story so here we go. The idea is for a mostly printed flying model rocket. The way I see it , it makes most sense to print the plastic parts of model rocket kits that you can't always get as separate parts and to just buy the rest off the shelf from model rocketry suppliers. So for this design it will comprise of 3D printed parts but off the shelf cardboard tubes for the rocket body and engine mounting system.
    So far I got what I call the fin body designed. I did the modeling in OnShape, its fantastically easy and fast to use, the entire process took about 20 minutes or less. That time frame includes sketching the part in 2D graph paper before modeling in 3D.
    As soon as I finished modeling the part, I decided to 3D print it to give it a test. Here are the results:
    I don't usually print with support material and the part was designed to be printed free of support, I just happened to have the check box in cura tagged, leftover from experimenting with profiles. The part came out pretty nice, even with the super tight dimensions of 0.5mm wide tips on the fins!!
    After the fin body was printed, I worked on the nose cone. The cone is also printable , it is mostly hollow, with a thick bottom, also on the bottom are slots for tying the shock cord and parachute to.
    Shock cord tie in:
    That's all for today, the cone is printing and I need to sleep!
View project log
