Status 6/27/16
A project log for Web Enabled Microscope
Enhance a microscope with web control, enabling gigapixel panoramic or focus stacked shots, live streaming/control and more!
justin-kennyJustin Kenny 06/27/2016 at 22:430 Comments
You'd think I would have learned my lesson from the first major microscope model mess-up. Turns out I messed up the model again by not accounting for a protrusion from the top of the rectangular bit which prevents the motor mount as-is from working, and it's also 2.6mm thinner than I accounted for. Anyways I updated the model and modified the motor mount to accomodate, which was pretty simple, just needed to mirror the mount and add a cutout for the protrusion. Here's the model as it stands now:
I printed the new focus motor mount along with the X/Y parts, which needed a little modification to print nicely. I also ended up dremeling out some more clearance for the focus motor mount. Here's a short video of the three axes with 3D printed parts functioning:
There's still a lot of slop in the X/Y positioner but it's also missing 3 screws which should help with that. If it is still not resolved I may need to add another linear rail to help with stability.
