Tentative Specifications:
| Type | Scanner Camera |
| Sensor | AMS (TAOS) TSL1406RS photodiode array, 768x1 px |
| Dimensions | 175 x 120 x 130mm (L x W x D, including lens), 175 x 120 x 74mm (without lens) |
| Image size | 1024 x 768 px (65mm x 48mm physical image) |
| Image format | 16-bit grayscale PGM (portable gray map), 48-bit color PPM |
| Power | 3.7v Lithium Polymer cell, 850 mAh |
| Integration time | 1/15000 - 1/10 seconds |
| Lens | Mamiya-Sekor 645 80mm f/2.8 N |
| Display | 1.8" Color TFT, 160 x 128 px |
| Weight | Approx. 1 kg |
Kevin Kadooka
Pop the top (just some black card stock) and you'll see that it's just a basswood skeleton with the electrical bits tacked on inside. A bit of open-cell foam is used to seal out extraneous light and improve contrast.
Stephen Holdaway
Ahron Wayne
Please tell me you’re hosting the code for this somewhere, you’re blowing my mind!
