INSTALATION OF A PRE-TESTING CHAMBER FLOW RECTIFIER PANEL
A project log for CierzScience Tunnel
A wind tunnel to study the behavior of the airflow about a study object to simulate the behavior of this object in a real situatIon
joel-villa-fariasJoel Villa Farias 08/18/2016 at 15:570 Comments
Making use of the remaining material of the panel rectifier of the acelerator cone, we have decided to use it to make a new panel rectifier that we will place between the exit of the machine of smoke and of the testing chamber.
With this new panel we want to rectify moreover the flow.
We have placed it in the section of the stabilizer between two frames of packing plastic to make sure that it remains fixed and the does not suck it the fan.
