Led is not equal Led
A project log for Pi Zero IOT Led Matrix Beamer
An 8x8 Led matix to display messages on the wall
alain-mauerAlain Mauer 06/13/2016 at 09:240 Comments
Hi all.
I used this 8x8 led matrix, because the leds are flat with a diffuser and well separated.
If you use normal Led's, they have already a lens, and together with the optic of the "Sprida" lamp you will not be able to focus them and all the led dots are overlapping.
