Assembled the first set of boards
A project log for 1090 MHz Mode S “extended squitter” transponder
An Aircraft Transponder for the Experimental Aviation Community to meet the 2020 FAA ADS-B mandate.
sn101124102SN:101124102 05/01/2018 at 19:270 Comments
Well, some errors where discovered in the first set of board, but I should still be able to use them for code development.
