• Software - HX711 Libraries
    Iulian Arcus09/18/2016 at 03:10 0 comments
    Initially I was going to skip this bit in the docs but writing these logs inspired me to do this thoroughly. So I went and code reviewed most of the libraries for the HX711 on github.
  • Hardware
    Iulian Arcus09/17/2016 at 23:07 0 comments
    So I built this hardware ages ago but it was up to the software to do the heavy lifting. I finally decided to pick this up again after finally getting around to figuring out the software platform I was going to use for my projects (updates for my other project coming soon). I decided Node-Red was the most appropriate as the data flow paradigm is well suited for sensor based data feeds.
    But this is about the hardware so read on.
