RPI (zero) Tesla Coil Controller
A small tesla coil controller designed to be run from a Raspberry PI
A tesla coil controller that uses the capabilities of a raspberry pi (Zero) to drive a Tesla coil via I2C and to play music from Midi files.
Now split into two tesla coils running from a single PI.
Software on the PI allows for manual scripting of the power and frequency of the Tesla coil bursts, a midi interface allows midi files to be played via ALSA and via external USB midi sources.
Always will be a work in progress
Construction and documentation still in progress, un-linked entries to come:-
Power Bridge
Gate Drive Transformer
Primary Capacitor / Tuning
Pi Software setup - Software details
PIC uP setup.
Wiring Up
I2C Driver Board
RS232 fibre to RPI
Secondary and topload construction
Boards are shared projects from OSH park.
I2C Driver
Power Bridge
View all 7 project logs
