Library Footprint Fixed
A project log for DPS-1520AB Server Supply Hotswap Breakout
Power Breakout for RC Chargers and ASIC Miners
charles-lakinsCharles Lakins 06/08/2016 at 19:510 Comments
The oshpark link is ok now to produce, the mounting tab holes were too far from the pcb edge to align with the pins too,
If you produced a board by chance you can snip off the pcb insert tabs and it should still work ok, Ive updated the oshpark link and libray file
