Magnet on a string
I'm going to make millions with this ;)
dropped something and you're too lazy to reach for it? Maybe it's under water but you're not. This needs to be done ASAP.
  • Expansion plans - give me you MacGyver tools (or links(or take me to your leader))
    davedarko06/12/2016 at 08:22 6 comments
    I'm currently in Austria because of work. I love this place, but there's no place like home, where you have EVERYTHING you need, when you need it. So I'm thinking of a kit that allows you to have some options to go through, with little parts. This list might be updated at anytime.
    You always need a paper clip for something. Maybe it's a temporary hook, or something to poke a reset button or to release a dvd from it's evil drive.
    A rubber band?
View project log
Voja Antonic wrote 06/10/2016 at 18:16 point
and the stick with velcro tape, to use it to pick the string if you drop it under the table
M.daSilva wrote 06/09/2016 at 15:37 point
Cost-reduction strategy: use metal wire instead of a string to spare on the knot-tying operation.
davedarko wrote 06/09/2016 at 15:44 point
but when you pull on it, it'll slide away from the magnet :(
M.daSilva wrote 06/09/2016 at 15:51 point
Oh. Right. Didn't think about this!
3D-print a part that clamps on the wire and traps the magnet... Much better than tying a simple, boring knot! I'm sure it'll be cost effective... Right?
davedarko wrote 06/09/2016 at 20:00 point
That shouldn't be that hard for me, with the good printer at home. I thought of designing a retractable mechanism for the string like those metal rulers that are so dangerous and awesome. Those with the button.
Yann Guidon / YGDES wrote 06/08/2016 at 20:35 point
Some strings are magnetic, but I s'pose it's the wrong forum.
deʃhipu wrote 06/08/2016 at 19:46 point
You should totally submit it to the hackaday prize!
