Axis
(Another) Homemade pick and place machine
AXIS is a project for a pick and place machine ― entirely built from scratch. Uses only standard components, and with a reduced amount of machined parts.
The project is more ambitious. The idea is to have several modules (Z-axis) interchangeable: for instance a pick and place module, a 3D printer module, or even a PCB engraver ― I started with pick and place module.
All software tools used are free of cost (or lite versions of commercial tools.). I have experience with Microchip processors (PIC32), and X32 compiler. I used EAGLE for control hardware design.
All mechanical parts are from eBay (Chinese components: Bearing, linear guides, etc), recycled (Step motors, bolts, pulleys, etc), aluminum homemade parts (I have a lathe and driller) or outsource water-jet cutting service.
Goal:
Design and construction of the machine, the control software and utility applications. There are some changes from the beginning.
Why:
  • For use in my work
  • For hobby
  • And definitely because I can.
Modules/Parts:
Mechanical Hardware:
  • Frame
  • Y-Axis
  • X-Axis
  • Z-Axis/Picker
  • Feeders
Electronic hardware:
  • 4 axis motion control board by software STM32F (First option)
  • 4 axis motion control board by STM32F and FPGA. Written in C++ and System Verilog. (Advanced option)
Embedded software/softcore:
  • Motion controller written in C++ and SystemVerilog
  • EOS operating system. (EOS on my GitHub channel)
Desktop software
  • Application control for pick and place operations.
  • Utility tools for data extraction from schematics and pcb (EDATools on my GitHub channel).
Tools used:
Mechanical design:
  • FreeCAD
  • LibreCAD
Electronic design:
  • Eagle (Schematic & PCB)
  • Quartus (FPGA sintesis)
  • Verilator (FPGA simulation and verification)
Windows software design:
  • Visual Studio 2019
  • C# compiler
Embedded software design:
  • STM32CubeIDE (Free STM32 compiler-ide, eclipse based)
Hardware tools/kits used:
Hardware developemen boards/kits:
  • Terasic DE0 Nano
  • STM32F429I-DISC1
  • STM32F746G-DISCO
Information sources
  • VBesment blog This is the main source of information about motor control and trajectory interpolation. I writed a new version of motion control based in this work.
  • Brian Dorey blog
AXIS-LimitSensor.rar
Schematic and board in Eagle format.
RAR Archive - 11.73 kB - 08/15/2019 at 10:38
Download
  • 3 × Step motor NEMA23 Step motor for X and Y axes. The Y axe uses two motors
  • 1 × Step motor NEMA17 Step motor for Z axis
  • 1 × Step motor NEMA11 holow shaft Step motor por rotate nozzle
  • 3 × Motor driver 2M542 or similar Drivers for NEMA23 motors
  • 1 × 36V/9A power supply Power supply for axes motors and drivers
View all 15 components
  • Updates on GitHub
    Rafael Serrano10/27/2019 at 11:28 0 comments
    Today I've added links to github for the operating system, pcb tools and some other utilities for the project.
  • Limit sensors
    Rafael Serrano08/11/2019 at 19:36 0 comments
    Lately this week I've installed the X and Y axis limit sensors. Each sensor is mounted into the supports of the linear guides. Said sensors have each two LED's indicators and work at 5 volts  this can be changed to any voltage, though.
    Thera are a RAR archive with schematics and board files in Eagle format.
  • Basic structure finished
    Rafael Serrano08/04/2018 at 10:21 0 comments
    After almost two years, the basic structure of the project is finally finished  ― axes X and Y.
    It is necessary to fix some details of the CAD files. Also, the list of materials has to be written as well. From now on, I will continue to develop the electronic controls of the motors and limit detectors.
    As for the Z axis, it is not yet decided how to implement it and is still under study.
    The Axis V1.0:
    Y motor detail view from rear:
    Y slider:
    Base structure:
    Y motors:
    Y free pulley detail:
    X motor:
    X axis from bottom:
    Y slider detail:
    View of X axis from motor side:
    That's all for now. Follow the project for more updates.
  • The last axis changes details
    Rafael Serrano04/01/2018 at 15:59 0 comments
    Y axis motor:
    Y axis pulley:
    X axis motor:
    X axis pulley:
  • Latest design changes.
    Rafael Serrano03/31/2018 at 20:15 0 comments
    After a few months of inactivity, I continue with the Axis project.
    Y axis:
    • Change in the system of hooking the drive belt, which involves raising the motor, and the free pulley.
    • Change in the support plate of the X axis
    X axis:
    • Remodeling complete, to work with the guides in vertical.
    • Use the same philosophy as in the Y axis
    Z axis:
    • Replanting the system. To study.
    In a few days the base structure and the Y axis will be completed.
  • Y-Axis motor module
    Rafael Serrano07/30/2017 at 12:52 0 comments
    Today I finished machining and mounting the Y-axis motor module. All measurements and tolerances seem correct. Anodizing is missing, but we'll leave it for later. In a few days I will have the entire structure.
  • Aluminium parts for Y-Axis
    Rafael Serrano07/02/2017 at 16:42 0 comments
    I've finally received the aluminum parts for the Y-axis assembly. They had been cut by water-jet. The holes and threads need to be machined.
  • 3 Axis FPGA controller
    Rafael Serrano12/03/2016 at 18:48 0 comments
    At the moment I have finished the prototype 3-axis motion controller with a DE0-Nano board. The simulation was performed with Verilator, and the synthesis and programming with Quartus-II v13.1.
    The model is written in system verilog. It includes several modules, the most important of which SCurveGenerator, LinearMotion and ALU, with a Look-Ahead carry.
    The system generates the STP and DIR signals for three step motor controllers. As parameters requires JERK, and the definition of S ramp. The process starts when receiving the GO signal.
    I forgot to mention that the number of axes can be configured using the NUM_AXIS parameter from 2 to 16
    Soon more and better
  • AxVision: Vision experiments (2)
    Rafael Serrano10/16/2016 at 12:12 0 comments
    Et voila!
    Edge detection on a clear black & white image, using an "USB microscope cam".
    Next:
    • Detection of rectangles (Components) and circles (Fiducials).
    • Compute centroid.
    • Compute angle deviation for rectangles.
    • Make real scale grid for calibration.
    Brainstorm:
    • Test type of ilumination (Red leds or white leds). Actually the microscope use 3 white leds.
    • Use hardware system FPGA+CAM (DE0 Nano) or software system (OpenMV) as an independent detection module. Expensive but beautifull.
    Rafael Serrano10/16/2016 at 11:39 0 comments
    While I'm waiting for the aluminum parts, I've started the vision tests using a webcam. The application is written in C#, using the Emgu.CV libraries. I'm experimenting with edge detection for the alignment of the components. To be continued...
View all 14 project logs
smtguide wrote 08/12/2017 at 16:06 point
Hi,
Thanks for sharing I really like your project it looks simple and efficient, would like to know if you could help me design similar project but head controlled by joystick (X-Y axis) and nozzle controlled by stick as well (Z axis).
Rafael Serrano wrote 03/31/2018 at 20:21 point
Sorry, I've been away for a few months and I have not been able to review the project. No problem, in a few days I will publish the design in GitHub, as well as photographs and videos.
Regard
