Added MOSFET
A project log for Ultrasonic Parking Aid without Arduino
Low power, battery operated ultrasonic parking aid.
jscjsc 07/01/2014 at 14:230 Comments
Updated board layout with a pull up resistor and a low side switch to power down the sensor. Hoping the external pull up will reduce the timeouts and checksum errors I still get occasionally. Waiting on PCBs now to test what I hope will be the final revision.
Also made the layout a little denser, to reduce board size.
