--UDP communication from ARM to outside world
Sending information to/from the FPGA via the ARM ethernet would be useful for a number of projects. The first code modifies the audio generation code to send the current note being played across a UDP connection to Matlab running on a desk machine. The ARM code opens a socket on port 9090 (do not use ports below 1024) and sends data once/sec to the port. The Matlab code running on the PC opens a UDP object, then just listens and echos the string to the command window.
--UDP communication from outside world to ARM
Sending slow (human rate) commands to a program can be done by setting up a non-blocking UDP receive function. Each time through the main event loop, the program checks for a valid packet. The Matlab code asks the human for a sine wave frequency and sends the number to the ARM. The ARM audio code computes the DDS increment for the frequency and sends the samples to the audio codec FIFO and the video process.
--UDP audio from Matlab >> ARM >> FPGA audio FIFO
Sending audio rate packets from Matlab code is fairly easy, but setting up a ACK function for sync is not because the Matlab UDP receive function is too slow. The result is an unsynced system that works most of the time. To further reduce overhead, eight audio samples were sent in each packet by matlab. At the ARM code end, the eight samples were duplicated 6 times each to expand the sample rate to 48 KHz, the default audio rate of the Qsys audio core. The main loop makes sure there is enough space in the FIFO for 48 samples, reads a packet, and loads the FIFO. Audio example file. The video processrecords elapsed time of audio using memory shared with the audio process.
Bruce Land
Raymond Lutz
Pansee Atta
lucio
Christoph Tack
