Lithium iron phosphate (LiFePO4) battery test
A project log for BeWi - Ultra-low power wireless Beacon sensors
Use BlueTooth BLE and WiFi beacon frame to transfer sensor data, achieve ultra-low power. Based on CC2541, ESP8266 and NRF24l01+
michael-wenMichael Wen 07/09/2016 at 14:270 Comments
I removed LDO from my NodeUSB (ESP8266) board, and use LiFePO4 battery to power it directly.
700 mAh able to run about 6 hours (345 minutes):
2016-07-08 13:04:30.324560
2016-07-08 18:50:05.973346
Then, I charged LiFePO4 battery (3.3V LDO directly) and ran another test:
2016-07-08 23:40:50
2016-07-09 01:15:34
That is 95 minutes, so about 27% of capacity, 190 mAh.
Second test is much batter (I charged longer this time, for 3 hours):
2016-07-09 13:25:182016-07-09 16:07:58162 minutes
That is about 47% of the capacity.
If use 3.5V LDO to charge LiFePO4 battery, it can reach 95% of capacity. I will test it next week.
