Lithium iron phosphate (LiFePO 4) battery
A project log for BeWi - Ultra-low power wireless Beacon sensors
Use BlueTooth BLE and WiFi beacon frame to transfer sensor data, achieve ultra-low power. Based on CC2541, ESP8266 and NRF24l01+
michael-wenMichael Wen 07/08/2016 at 15:060 Comments
Today I started testing LiFePO4 battery. I had the idea of using LiFePO4 battery for few months. Now I just received the shipment early this week.
Few benefits use LiFePO4 battery:
  1. Can use LiFePO4 battery directly power MCU, without LDO or buck converter. LiFePO4 battery discharge at 3.2V. This is huge for ultra-low power applications that average 3-15 uA. Even the really good LDO still consume 2-5 uA when MCU is sleep.
  2. Better high temperature performance.
  3. Long life, 2,000 charge/discharge cycles
  4. Large overcharge tolerance and safer performance
  5. Simplified battery management system and battery charger
