Since the project is complete we have released all the documents regarding the I2C Encoder V2.
On GitHub there are all the source files of the firmware and of the hardware!
Under the folder Firmware we have uploaded the hole MPLAB X project. While under the folder Hardware there all the production document, we have also added the 3D .STEP file.
The PCB project is available on CircuitMaker.
The final I2C register map is the following:
Respect to the original version we have changed several register, like the status registers, period register and the fade registers.
