Lens Calculation Website
A project log for Arduino Glasses a HMD for Multimeter
Building an HMD with no special parts, to make work easier and safer
alain-mauerAlain Mauer 07/18/2016 at 11:350 Comments
And again optic. I found this website to calculate the object distance.
http://hyperphysics.phy-astr.gsu.edu/hbase/geoopt/image4.html
The best optics for this project are lenses with a focal length between 100mm and 120mm.
The Maginifiging effect will be between 2.9x and 3.5x, witch gave the best results and the distance between the lens and the display will be something between 70mm and 80mm.
